Got my SAFC 2 installed & tunned by all star garage. All good.
EDIT: realistically SAFC is just a basic A/F ratio signal bender, any decent import work shop should be able to install & tune with no problem.
Edited by Mayuri Krab
not sure why you want a bee-r limiter besides scaring people
+1 to All star and Hyper
and everyone else would say check the consolidated workshop
ive had alot of people refer me to all star so i think i'll get the safc neo tuned there, thanks guys!
destroyed the rings? how'd it manage to do that..i didnt buy the limiter to get my skyline to blow flames like about 99.8% of people who have them do, i just want the limiter there as a restraint so i dont rev my car anything over 4000rpm to protect the motor from my p plater right foot -.-" im not saying im a hoon or anything i dont do burnouts or drift all im saying is i cant resist getting her on boost every now and then like im sure most skyline owners do no matter how old they despite the obvious loss in fuel economy :)
BS ^^^
Bee*R is good for only one thing.. scaring people! Letting it crack past someone who just cut you off is the best.
There is a factory rev limiter on the car, setting it for 4k will make the car a nightmare to drive in the city.
If you don't have enough self control to drive it accordingly then buy a mazda 121.
Edited by BANGN
Go ahead and install it. When it destroys your already fragile oil pump, you'll know what we mean.
Oh yeah, and I was a P-plater with a powerful Skyline. Went the 4 months without passing 3k. Self-restraint really isnt that hard. Otherwise, you've got the wrong car.
why do people buy high powered skylines and dont pass 3k...why not buy n/a :)
I'm an apprentice mechanic... My car is tuned very rich, so even driving it easily it uses a fair bit of fuel.
Plus I managed to lose my licence WITHOUT passing 3k, so not sure how I would have gone if I did have a heavier foot...
I'm buying a slow daily, so not a worry.
even setting it at 4k reving to that you will still make noises once youve hit limit ive played with all the settings on the bee-r suprisingly even at 2k limit you shoot flames and make gunshot noises but yeh
if you want to set limits buy a pfc and you have 2 units in one
I'm a P plater with no self restraint, still have my license and have travelled 30,000 in my first 6 months of driving
Lol you siad you have no "self-restraint".
That means you are saying you don't restrain yourself from doing anything in your car and that you havn't been caught yet :(
BTW GL with the sale of my old rod :)
why do people buy high powered skylines and dont pass 3k...why not buy n/a :(
I'm too chicken, anything over 50% throttle on this car scares me :)
I have no problem revving the Corolla near red line (6k) everywhere I go as even if I do that with foot nailed down the car will still be going at snail pace... although I hate that horrible engine noise when that little 1.8 N/A is revved near red line, sounds like its dying.
Lol@not revving past 3 or 4k, how do you guys even get anywhere.
RAC suggests you should accelerate from 0 to 20km/h in 5 seconds or longer :)
aahahah even at at 4k theres a fair chance if u smash into the limiter ur still putting the oil pump and turbo and pistons in danger, i dont understand how its so hard to drive with a bit of restraint, if u cant u prolly shouldnt have licence, let alone a skyline givving the rest of us a bad name,
skyline arent that powerful and fully hectic that u need to restrain it to drive safley,
FAIL
rhys please explain how the bee*r damages the engine. i was thinking of getting it to scare the spiders that live in my exhaust and not old people :(
he mentioned something about it destroying the owners exisitng fragile fuel pump?
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
