Hey Guys,
Well my pads are getting near to the wear limits and Im looking to get some new ones. From what I have read on here they are the same as 350Z touring pads?
My question is what pads are people using and what are they using the car for? I my car is purely for the street but as I live in the Perth hills the brakes get a good beating
every now and then :P So obviously I dont want a pad thats too aggressive on the rotors or one that has a heat range suited for the track, but at the same time id like slightly increased performance over stock.
Does anyone have any recommendations for what pad I should use and where I may find them?
Cheers,
Brendan
https://www.sau.com.au/forums/topic/319071-m35-brake-pads/
Yep, M35 brakes are the same a Z33 (350z) touring.
I recommend QFM A1RM pads. Straight fit, no squeal. I have Nismo rims which would show up brake dust up in a second and the only dust I have on my wheels is from the dirt road I live on.
Cheap too, around $180 delivered for all 4 corners :)
Link? Sure, I got mine through GSL Rallysport or Jetpilot1986 on SAU.
https://www.sau.com.au/forums/topic/319071-m35-brake-pads/#findComment-5212108
Awesome! Sounds like those pads cover all the bases. They also seem to beat the Project Mu pads also listed on GSL Rallysport for frictional coefficient.
Thanks very much for the info, Ill send Jetpilot1986 a PM later today and order some :)
https://www.sau.com.au/forums/topic/319071-m35-brake-pads/#findComment-5212395
what are the pads like rda do?
I'm using RDA's in mine at the moment, nice cold bite, good fade resistance, but quite dusty. Even paying retail they're only $35 a set. Not unhappy, but next time I'll be going QFM; everyone raves about the A1RM's
https://www.sau.com.au/forums/topic/319071-m35-brake-pads/#findComment-5213132
Hey Guys,
every now and then :) So obviously I dont want a pad thats too aggressive on the rotors or one that has a heat range suited for the track, but at the same time id like slightly increased performance over stock.
Cheers,
Brendan
Hi Brendan,
It really depends on which side of the compromise fence you sit. The A1RM is phenomenally good pad as the guys above have said (and is a Ferodo DS2500 type equivalent pad performance wise), and although it is 100% streetable, it will have slightly higher rotor wear than a normal street pad, which if that's not a drama, then they'll be the best pads you'll ever run on the street. The next pad down, the HPX is a Bendix Ultimate equivalent performance wise, but very low dust and rotor wear, and is generally enough for most people on the street, even with a bit of heavy duty work.
The A1RM to suit is $119 per axle set front or rear. The HPX is $79 per axle set front or rear. Shipping is free when you order front and rear pads together, or else $8 per axle set individually.
If you wanted to take a bet each way, A1RM front and HPX rear is quite a common combo we sell.
Regards,
Greg
https://www.sau.com.au/forums/topic/319071-m35-brake-pads/#findComment-5214135
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
