Hi guys
thought it was time to put the build up in a post. I brought this shell back in 2007 as a stripped out half roller no rear end with the thoughts of building an all out track car.
As it turns out after a few beers and researching numbers and just a weird feeling about this car and turns out to be a Nismo shell #32 that has been painted in japan bayside blue.
Since I found that out I decided to put it back to orginal condition with some power up mods etc.
The engine is stripped and parts have been ordered they are:
wiseco 86.5mm pistons
eagle forged rods
cometic gasket kit
kelford cams 272 duration 10.2mm lift
tomei cam gears
gates timing belt
DMD Tuning spec forged oil pump
DMD oil head drain
DMD baffled large capacity sump
DMD spec custom head port and polish
Surpertech stainless 1mm oversize valves
Surpertech double valve springs
Supertech titanium valve spring retainers
Supertech valve guides
Supertech buckets
Nismo 14411-06U00 orginal rebuilt turbo's
Nistune ecu tuned by DMD
Standard airbox with custom DMD ram air induction into stock airbox
R34 GTR intercooler (but will prob need an upgrade to 100mm)
Jim Berry Clutch
DMD modified standard AFM's or DMD's MAP to MAF convertor
Standard block as per Nismo orginal spec but cyro treated for stength
Arp bolt kit
JJR cooler pipt kit
JJR dump and front pipe
Apexi N1 exhaust cat back
Oil cooler yet to be decided
The car will be painted back to the orginal gun metal grey with the orginal N1 spec body kit.
Rims will be a month by month choice of either R32 GTR, custom bronze R33 GTR as what was on my R32 GTS4 or work XD9's 18x10 + 15 with the fatest rubber that will fit them.
Interior will remain pretty much bog stock apart from the flip out DVD touch screen head unit which will be showing our custom data logging info with every engine parameter hooked through the car pc.
Brand new standard gtr shocks will take duties of street and drag strip with a set of coilovers yet to be decided for track work. Super pro camber bushes for the front Noltec subframe bushes in the rear with standard rear bushes for the time being. DMD custom hicas lock bar setup and hub mod to be similar to group A spec setup.
Chrome Molly cams spec bolt in half cage will get bent up and installed with bare minimum bars for street and cross bars for the track.
Standard GTR brakes with upgraded pad DBA 4000 rotors cusco cylinder stopper martini high temp brake fluid and no abs as per nismo spec.
Larger rotor upgrade may happen for track work.
That's about all I can think of for the min I have got more pics somewhere of the car when I got it but here is a small taste of the car rolling and the engine in a million pieces on the bench dont mind the mess had to stack all the old parts up as lack of room for other work.
We have got the engine bay all painted and ready for the engine when it's built but haven't taken any pictures yet.
  • Replies 54
Hey mate
yeah the tomei buckets are nice and are actually a better price out of japan then what I can get out of the US.
The oil pump will be a forged set of N1 gears that I get CNC made up. I have a few contacts in the engineering world that do reverse engineering and they did it for a set of stock N1 gears. Will have new oil pressure relief sping set slightly higher.
Basically it will be very similar to the Nitto oil pump.
Also I think I forgot our own cylinder head drain I turned up on the lathe.
David
Hey Russ
how's things?? How's the old 32 going still hitting the track hard with it??
The specs can get very hazy on the Nismo edition but think of it as basically a N1 without the N1 block and in gun metal grey.
If you look at this link on wiki it tells you a lot.
http://en.wikipedia.org/wiki/R32_gtr
cool build man, gonna watch thsi progress
heres the quote from wiki on the nismo edition
"The Skyline GT-R 'Nismo', introduced in February 22, 1990, has a total production of 560 units as required for the "Evolution" models regulation (over 500). Its purpose is to homologate a number of aerodynamic changes used in Group A racing. Changes include additional ducts in the front bumper to improve airflow to the intercooler, a bonnet lip spoiler to direct more air into the engine bay, and an additional boot lip spoiler to provide more downforce. The 'Nismo' GT-R was only available in Gunmetal Grey."
Thanks mate
keep a close eye on it.
Ordered the cams today should be here Thursday
That's pretty much what they are got steel wheel turbos optional a/c no abs and rear wiper plus all the areo mods.
Few more pics guys.
Forgot to add fuel system. Will ne Nismo 555cc injectors I picked these up a few years back for my GTS4. Nismo FPR standard fuel rail Bosch 023 700hp intake fuel pump. Very simple but effective. As some might know gibbson motorsport gtr's used these injectors with a standard rail but different pump setup and made a lazy 580hp with the same turbo's
Started the cylinder head drain last night still deciding what fitting size to use I'm leaning to dash 8 as it is smaller than what others using dash 10 but won't have the same drain capacity but will clear the firewall better
  • 3 weeks later...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
