Driver Taining Day Rac Driving Centre Kewdale
R DIRTY 3
 Share
  • Replies 169
Posted Images
Landscribble, Davyboy pulled out first so you have his spot.
Hank, if you cant make it for certain, there is 1 spot remaining.
First in first served...i wont be on here until later in the morning so best just rock up and try your luck.
Definitely pulled out. My spot is available.
Not doing the day running two spacers at the front and two different width/offset wheels on the back. What a horrible day I've had!
Is anyone actually going? So many people have pulled out!!
Unbelievably, my car is still running... My cars never run this late the bight before AHG! I may actually make it, fivers crossed...
James, I always bring my camera dude!!
 Share
    • I’ve just installed a Uniclutch sport into my R32. I’ve been blown away by it… it drives like a stock Toyota Corolla. It doesn’t make sense to me that a performance clutch can drive this well. I was about to pull the trigger on a Nismo Coppermix twin plate when I discovered the Uniclutch and decided to give that a shot instead. They’ve changed the game and I couldn’t be happier.    I was previously using an Extreme cushioned button clutch with lightened flywheel. I’m still using the same lightened flywheel with the Uniclutch.
    • Mmmm no, that's a white series 2 R33 GTS-t
    • Oh and.... "no bubble on the dash" ---> immediate no mod status.
    • To be Frank (always liked that name), I reckon this is a better idea. I'm an R32 man from day 1 and the really good surviving examples that are still in stock form should stay that way. Let ye conscience guide you my son 🙂
    • Serious answer: The Japanese call them "HCR32純正アルミホイール" (HCR32 Junsei arumi wheel). https://www.google.com/search?sca_esv=9781a9b17bdb0a90&q=HCR32純正アルミホイール&uds=ADvngMi969x8VO53s3Ns6zY_q0mz1wQSG62T0CP-XYz351Bz4k-UlCLmEIs3_DOvTIrJbtR53zUINohMWufGSNcE7u-Sy3WX5TUjyDJHK7ocoDfeYw5W1tSwzUlYREw7kf4AsG4TMceIn7jdSxdsPXSr015SPQ0N4d0VoByGkenzSrAe8dyXSHA-cFV7LpaAVKCIPCKphRBK4ExnPj5Wp8Ymbl6ZrzN4uV9O1oqNcySxxJLogfY6FULbGlMPmheHkf5T89XXkWHUmA-Kn76muIhfC4LNQ0WaaP4QrndS6u2ovf8NUIsYJ7oFJ81Is4MDHNu_WMQr5vRcNCw-OO7NiSgP3rP02XVontjydtRrPYYnhoyPrwFoPHU&udm=2&prmd=isvnmbtz&sa=X&ved=2ahUKEwjYlNzYxcuGAxW72DQHHb8ODIAQtKgLegQIDhAB&biw=1920&bih=911&dpr=1 The English name for them would be "(insert model name) genuine wheels"?  As a side note, they fit perfectly on 1st and 2nd gen Suzuki Swift Sports: https://www.google.com/search?q=HCR32純正アルミホイール+スズキスイフト&sca_esv=9781a9b17bdb0a90&udm=2&biw=1920&bih=911&ei=aBBkZsT2KMS60-kP8IGZwAE&ved=0ahUKEwjEyoTbxcuGAxVE3TQHHfBABhgQ4dUDCBA&uact=5&oq=HCR32純正アルミホイール+スズキスイフト&gs_lp=Egxnd3Mtd2l6LXNlcnAiNkhDUjMy57SU5q2j44Ki44Or44Of44Ob44Kk44O844OrIOOCueOCuuOCreOCueOCpOODleODiEjCXFCgA1iiWHALeACQAQCYAYkBoAHzDaoBBDE4LjK4AQPIAQD4AQGYAgCgAgCYAwCIBgGSBwCgB_wH&sclient=gws-wiz-serp
