Im sure the topic has been hashed over several times......
Just got my policy renewal today and nearly fell over cause in the 2 yrs ive had my car the policy has gone up over $400 bucks! And ive never claimed or had any driving offences what so ever!
Im insured with Lumley Special Vehicles.
2008 policy was $1000
2009 policy was $1250 ish
today $1440
Can any of you other 34 drivers or anyone in general tell me who you insure with and approx how much, cause this is getting out of hand the policy going up by a couple of hundred every year!
Thanks Donna
https://www.sau.com.au/forums/topic/319560-insurance/
  • Replies 46
today $1440
Thanks Donna
mine has gone down every year, time for a new insurer me thinks
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218582
today $1440
Thanks Donna
How old are you?
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218627
30 in a couple of months, so im no teeny-bopper! lol lol
Seriously change your insurer. I am with Shannons on an agreed value deal for 6/700 a year (cant recall excactly without looking at the policy)
You are getting right royally rogered atm.
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218649
been making some inquiries ......
shannons about $800 with $500 excess
just car $712 with $1500 excess
so ill definetly be taking one of those instead i think .....
when i called LSV i got the same bla bla bla story i did last year, shannons has an agreed value and with just car its a few grand under that.
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5218681
Even though Suncorp owns Just Car and Shannons have you tried them for a quote too? R33 GTST with Just Car was $1400 at 25 with perfect history in Toowoomba. Suncorp quoted $690 at the time iirc
I find that hard to believe. I've rung Shannon and Suncorp just to check recently and Shannon doesnt insure a daily car and Suncorp was like 2k. I'm sticking with Just Car for now at around 900 premium and 1.5k excess.
PS: Daily Car = one and only car regardless of how many times you drive a week. The other condition to fulfil if you have 2 cars is you can only drive the insured car for 2 or 3times a week if I remembered correctly.
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5222000
I believe AAMI owns just cars, not suncorp. But they won't insure anything modified/import, they'll just direct you to just cars.
Just cars however will insure anything, but they will charge more than AAMI. It was about half as much to insure my shitbox XF with AAMI than it was with just cars
https://www.sau.com.au/forums/topic/319560-insurance/#findComment-5222137
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
