Hey tommmo hows the motor going its been a few weeks since last update did she start up alright? Keen to hear the news.
well the good news is, the car has got a sweet running heart again!
the bad news is.. ive been sooo busy over the last 2 weeks, i've only had time to drive it home... thats it!! :unsure:
keen to take it out this sunday, and then due for a proper tune up friday week
got home after work last night and just couldnt help myself.. picked up the keys and went for a nice drive to hahndorf
I must say Paul has done a fantastic job :3some: its very quiet and smooth..... until I put my foot down and you hear its growl via the exhaust.
I had the biggest, cheesiest grin on my face driving back down the hill.
Cannot wait until the tune next week!!!
Coming home along portrush rd, I saw headlights speeding towards me in my rearview, I automatically thought "great.. gonna get pulled over and harrased by the po-po first night out" turned out to be an fpv, he pulled up next to me.. revving whilst driving side by side, trying to get my attention.
I didn't respond, douche then floored it, lost traction and almost lost it.. friggin idiot! Where's the police when you need them?
The popo are where you don't need them and when you need them they take 30mins to an hour
On the other note. Good to hear that your car is back up and running again mate :D
picked my r32 up to start running-in last thursday, only driven it home so far
but was amazed at how strong the fresh Rb26 engine felt.
definately a heap more power than my Rb25
even with only steel-wheel rebuilt turbo's the power/punch is pretty brutal.
hoping to get out for a few days driving (running-in) soon. then can get back to boostworx for the tune
  • 3 weeks later...
  • 3 weeks later...
Updates?
Few things came up (not car related), hasn't been tuned yet.
Its at the workshop:
Injectors installed
Fuel Pump installed
AFMs installed
PFC installed
Ready to rock'n'roll!!
tuner is away until friday though, will hopefully have a result then.
Edited by Tommmo
Not entirely happy with the tune.. Terrible on cold starts, need to turn ignition over twice before it starts, when it does, timing is all retarded and drives sluggish.
A lot better when it warms up, but still a bit hesitant when just cruising along at 2500rpm. Not sure if this has something to do with the larger injectors? When foot is 3/4 or flat on the throttle, it does pull very smoothly.
I'd like to see final boost setting around 22psi and lean it out a bit more, noticed it's chewing through petrol pretty quickly at the moment!
John does know what he's doing..
you're right.... i've been going there for a few years now, he's always been good.
Might give him another crack at it, just give him a de-brief of how its responding on the road etc
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
