Will update this as I pull more gear off the car. However, it starts with:
genuine eastbear mirrors, blue : $150
Genuine eastbear (I think?) carbon bonnet, painted. $350
Genuine TRUST front bar, been stitched up a bit. $250
GTR N1 headlights, one lens has slight crack from stone chip: $200
GTR indicators, both in good nick. $150
GTR guards, both realtivly straight, def in need of some prep and paint. $200
GTR bootlid, no wing. $50
GTR doors, no glass, no reinforcments, great for track cars. $40ea
Shell, race only non compliable shell, decent condition. come check it out. $500 (more pending what is left on it)
10 point bolt in cage, looks to be safety21, around the dash. $900
Cobra fixed back bucket seat, wrap around type. $300
Blitz dual SBC boost controller: $300
B pillar floor brace. $150
C pillar brace. $150
Strut brace front and rear pair $200
R32/R33 GTR apexi power fc. with handcontroller $900
RB26 engine loom, perfect condition. $250
GTR castor rods adjustable jap chunky items: $150
China rear camber arms $80
China rear traction arms $80
China hicas lock bar $80
GTR Diff, OS giken 2way (supposedly, will disassemble to confirm) $800
GTR gearbox with OS giken gearset (supposedly, will disassemble to confirm) offers
OS giken twin plate clutch (will check meat when out) $500
Big jap brand swaybars, adjustable, will get diameter and brands when out of car $250 each
Perspex rear window, slightly yellow, prob needs clean. suit R32 $100
R32 quarter glass $50 each (pull em out yourself)
R32 GTR Vspec bootlip: $100
R32 GTR grill: $80
R32 GTR/gts4 coilovers look to be tein will confirm when out $500
HKS cast alloy cooler piping kit genuine: $250
Dual blitz BOV: $200 pair
TRUST oil cooler relocator and lines, no core (was damaged) $200
R32 GTR brakes. Solid rotors, look to be endless pads (will confirm) $800
S1 Splitfire coilpacks, less than 6 months old. $400
Fuel cell, will check litreage, $220
Bosch 044 pumps x2 $140 each
ARE custom surge tank, 2.5 litres by the looks of it will confirm $250
Magnafuel twin entry fuel reg, big HP one, $250
contact buckna. 0427282562
or reply here.
all parts located in brisbane. can post realistic parts.
request pics for now, will upload a heap this weekend.
https://www.sau.com.au/forums/topic/319642-stripping-r32-gtr-track-car/
  • Replies 50
Overwhelming amount of PM's.
Will get back to everyone asap. Damn 1 pm every 5 minute rule is driving me insane.
Diff is definently OS giken 2way.
Gearbox needs to be check if it's 123 or 12345 gearset. Will update once gearbox is apart.
Yes chris. you have dibs on bonnet. pics are coming through to you in a moment.
here are some random shots I just took with my iphone, gotta go back to work.
excuse the quality, couldn't find the digicam.
I really hope they work!
Hey all. Sorry about missed calls. Hard to answer all calls while stripping car.
Have a few people interested in the gbox. Will obviously come with transfer case.
I do have tailshaft. $150
trying to reply to all the pm's.
will check freight costs tomorrow for everyone who's enquired and shoot pm's off.
also.
HKS hard piping kit sold.
Bosch 044 sold. turns out one was a BOSCH 910, this is still available
Brakes sold.
Rear cradle sold complete. (this means, all rear arms, diff, shafts, hubs etc)
vspec bootlip sold.
seat sold
cage sold.
bonnet sold
guards, headlights, indicators sold.
will update if any of the above items that are on hold or sold don't actually get picked up.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
