Atr43ss-2 Prototype Initial Tune 250rwkws 18psi<2500rpm, Stupidly Responsive
  • Replies 118
Posted Images
Here's the link of the video footage:
On road for normal driving its good, feels like always on boost. Once floored just wheel spin every where. 2nd Gear wheel spin from 3500RPM all the way to 7000RPM. Good responsive street turbo.
To bolton to stock setup need 2x slicon hoses, Exhaust and manifold plus lines bolton, can be high flowed into stock turbo.
Car's got 800cc injectors, Z32 AFM, FMIC, Exhaust, Clutch, BOV, Nistune chip.
what can you put together for a VL Berlina turbo that will bolt on...lines mani etc.
mint car that needs to look absolutely unmodified.
pm or post here.
Edited by Swiper the Fox
the boost looks like it drops down to around 14.5psi from 18psi ..... if you could some how get it holding 18psi to redline, im sure it would make more power....
also notced youve lost a bit of the bottom of the graph.... would love to see the bottom end of the power curve
What's special about this compared to ur normal ATR43?? what's different about it?
Yeah im curious about specs of this turbo aswell, what makes it so special to spool up and be on boost that early and that hard, yet still make allright top end?
Edited by PM-R33
This turbo was engineered for max street driving ability. Its more of a independent turbo that has no shared features to all other ATR43 models.
We've also done some testing on it using different actuators and settings with wastegate controller. I will discuss that in my thread lateron this evening.
    • Keen to see how this goes, would love some standard mats
    • Learned a bit @PranK To add a twist to this take, I've done some further investigation and turns out I don't know if I even have coilovers. I have Mugen Showa on all corners, which appear to be struts / springs online. Someone may be able to correct me if I'm wrong.
    • Well, i've been told it's going to be in Poland around october - november. It should set off by the end of this month. Waiting for it to arrive is the easy part, searching for the right car, wake up in the middle of the night to see the photos and decide whether to bid or not - that was difficult
    • Thanks mate, i'll keep that in mind. Not sure though if the black carpet will fit grey interior. I'd prefer original Stagea set but if i fail to find one in another few weeks, i will probably come back to you. p.s. - is this original, licensed Nismo product?
    • I'm a strong believer that old sports cars should be reserved as weekend cars and owned by mechanically inclined people. The risk-reward ratio is only acceptable under those conditions.
