Hi there all, New to the site. I currently have a problem with my Series 1 gtst with a series 2 Rb25DET. It runs fine when cold but when it gets warmer it tends to feel as if its restricting somewhere.
Ive checked the CAS, Injectors, Computer, Spark plugs.
Im really stuck on this problem the only thing i have not done of the above is replace the Crank angle sensor( Altho it looks phyisically fine) which ill be giving a shot on monday, If anyone is able to lend a hand it would be very much appreaciated. Thanks jamie.
https://www.sau.com.au/forums/topic/319733-r33-gtst-problem/
Im really stuck on this problem the only thing i have not done of the above is replace the Crank angle sensor( Altho it looks physically fine) which ill be giving a shot on monday, If anyone is able to lend a hand it would be very much appreciated. Thanks jamie.
alright well first no one can really help much as that could be from anything,
what has been done to the car, ie aftermarket parts, have you done a tune up at all in the past while like spark plugs , fuel filter ect ect.
we need more info and how long has it been happening for.
tell us everything !! :cool:
What do u mean by restricting?
When does it feel like its restricting? (Revs/speed/boost)
Umm maybe your coilpacks but yeah I dunno jut give as much info as possible and someone on here should be able to sort it out :cool:
What sort of spark plugs does it have/did u replace them with?
does it splutter and stall? or just feel like it's asthmatic? . a few things for you to change imo would be the water temp sensor to the ecu , then the air sensor thingy on the exhaust that i can't remember the name of :cool: , clean the afm out with co cleaner , check fuel pressure (actually, do that first ) , change fuel filter . ;)
Thanks for the replys guys, Ive also had the coilpacks checked and apprently are fine which is leading me to the CAS, It Defiently increases the problem when i run higher boost, The revs drop but not to stalling point normally sits about 1000rpm, Random drops to 500 on idle. Im thinking the CAS is internally damaged..
Aftermarket parts are the following:
3" Turboback Trust exhaust.
Turbo smart boost controller.
Power FC.
Garret GT30 turbo.
Bigger injectors.
Front mount intercooler.
Spitfire coilpacks.
Nismo Diff.
The restricting defiently feels like fuel/spark. Altho ive been told by the dyno results what is happening is my injectors are all switching off for like a milisecond, So im thinking earth/wiring problem Or Crank angle sensor =/
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
