hpt_simon Posted May 9, 2010 Author Share Posted May 9, 2010 so, problem here is, there is no experienced machinists in any sort of racing here in spain. so i will have to attack this myself, so, when grout filing, how do i do it, do i just remoove all the lower core plugss, and fill heach one until it is about to reach to hole?, so i just do one? or do i do each so it fill equally? do i just fill the ones on he exhaust side, or take all engine ones out? this car will be producing around the 800bhp and lots of revs, will this be any sort of handycap on the track with temperatures? not shure what ambien tems you get there in summer, but its around 30-35ºC here in summer thanks simon Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5223624 Share on other sites More sharing options...
datsqik Posted May 9, 2010 Share Posted May 9, 2010 I leave all the welsh plugs in as you will at least need to fill to the top of the lower welsh plugs. I usually replace them all with new stainless plugs after I have hot tanked the block before I hardblok them. You can buy hardblok as either a half fill (usually 2 small bags but sometimes 1 big bag) or you can buy it as full fill which is 2 large bags. Once the block is clean and welsh plugs in place the block needs to be upright and level preferably on an engine stand. Mix the hardblok to manufacturers recommendations in small batches as it goes off fairly quickly. I prefer to do the job with 2 people using a small funnel and some wire to help get it thru the funnel and then level it out at the bottom of the block. I just pour some down a water gallery at each cylinder then work it around with the wire. I just work my way around the block. Its best to bore/hone and deck the block a few days after it has set. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5223705 Share on other sites More sharing options...
datsqik Posted May 9, 2010 Share Posted May 9, 2010 If a block is to be bored/honed using a torque plate or not then hardblok should be used before hand and same goes for align honing of the crank tunnel. If sleeving a 30 block I would probably fit the sleeves first then use some hardblok between the cylinders with the engine on its side with the welsh plugs out. Do one side then the other after the first side is hard enough to turn the block on its other side. The reason I do this is that the standard cylinders end up fairly thin towards the top of the block between the cylinders when machining to suit the sleeves and in some spots can break thru to the water jacket. By adding some hardblok in these areas can add some strength back into the block. Once that is done you can fit the welsh plugs back in and do a normal short fill or a full fill for an all out drag engine. You can then bore/hone the sleeves and deck the block etc. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5223747 Share on other sites More sharing options...
nsmo30tt Posted May 10, 2010 Share Posted May 10, 2010 would you say sleeving the block benefits it strength wise? I haven't seen any for sale and unsure of price so was just wondering if it would be worth the time and effort Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5224618 Share on other sites More sharing options...
datsqik Posted May 19, 2010 Share Posted May 19, 2010 I dont think that sleeving would strengthen the block at all but it does strengthen the cylinder itself as the darton sleeves are much higher quality than the standard cast bore. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5243918 Share on other sites More sharing options...
[200] Posted May 19, 2010 Share Posted May 19, 2010 datsqik said: I dont think that sleeving would strengthen the block at all but it does strengthen the cylinder itself as the darton sleeves are much higher quality than the standard cast bore. do you use the rb26 sleeves on the 30s? Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5243939 Share on other sites More sharing options...
jas/slo32 Posted May 20, 2010 Share Posted May 20, 2010 Here is a block mod i wouldnt recomend to anyone Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245084 Share on other sites More sharing options...
Fitzpatrick Speed Works Posted May 20, 2010 Share Posted May 20, 2010 LOL I had a good chuckle. Does save weight though Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245122 Share on other sites More sharing options...
Cartman Posted May 20, 2010 Share Posted May 20, 2010 jas/slo32 said: Here is a block mod i wouldnt recomend to anyone nice breather holes. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245167 Share on other sites More sharing options...
nsmo30tt Posted May 20, 2010 Share Posted May 20, 2010 well I have seen darton sleeves for RB30 and was thinking of getting some one day, from what you said I gather that you could run higher boost more safely as the cylinders are stronger? Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245179 Share on other sites More sharing options...
hpt_simon Posted May 20, 2010 Author Share Posted May 20, 2010 do we have to do that to every cylinder?¿ Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245760 Share on other sites More sharing options...
hpt_simon Posted May 20, 2010 Author Share Posted May 20, 2010 oh, another question, how would a block / girdle brace compare to half block fill? im very scared about filling up half the block and doing it wrong and ending up overheating every race meating Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245761 Share on other sites More sharing options...
Swiper the Fox Posted May 20, 2010 Share Posted May 20, 2010 (edited) hpt_simon said: oh, another question, how would a block / girdle brace compare to half block fill?im very scared about filling up half the block and doing it wrong and ending up overheating every race meating Simon...you only do up to the bottom of the welsh plugs...nowhere near half fill. Read what i have already written previously. Harmonic vibration and the added stresses of the front diff twisting them is what cracks the blocks....unless you can fit a brace that is stronger than the bracing and ribbing already built into an RB26 block then i really doubt how effective it could be. Swiper the Fox said: Some of the circuit racers have commented that they have lower logged temps after grouting. When you really think about how a thermostat controlled cooling system works it actually makes sense. It may have you running a few degrees cooler mate. Edited May 20, 2010 by Swiper the Fox Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245780 Share on other sites More sharing options...
datsqik Posted May 21, 2010 Share Posted May 21, 2010 Darton do sleeves for the 30 which is a bit longer than the 26 sleeves. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5245989 Share on other sites More sharing options...
hpt_simon Posted May 21, 2010 Author Share Posted May 21, 2010 perfetc, thanks swiper. so how do you apply the block filler personally? do you take the welsh plugs out, or have a measured amout of filler and pour it through the top of the water outlets? thanks gain simon Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5247050 Share on other sites More sharing options...
Swiper the Fox Posted May 21, 2010 Share Posted May 21, 2010 hpt_simon said: perfetc, thanks swiper.so how do you apply the block filler personally? do you take the welsh plugs out, or have a measured amout of filler and pour it through the top of the water outlets? thanks gain simon take the plugs out so you can monitor whats going on...leave the front one thats lower near the thermostat in. Mix up hardblock...using a funnel and some mig wire carefully pour small amounts at a time down the water jacket holes. You will have to use the wire to help it through the funnel and also work it around outside of the bores as it doesn't flow very well. Make sure block is nice and level and leave for a few days till nice and hard. there is a couple of other little things i also do that are not particularly necessary but thats enough info to get the job done. practice on another block is a good idea...especially one that has punched a rod out through the bottom that will only end up as scrap. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5247097 Share on other sites More sharing options...
T04GTR Posted May 22, 2010 Share Posted May 22, 2010 no need for main studs. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5248410 Share on other sites More sharing options...
T04GTR Posted May 22, 2010 Share Posted May 22, 2010 so do we know if any rb30 rods can come with pressure fed wrist pins? i only ask cause of a very tough 26 i seen stripped, was drysumped and the little ends were all f**ked. one had punched the bronze out of the rod and had hammerd the piston pin hole in the piston to the point bits of piston were squashed out like the little end.. Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5248432 Share on other sites More sharing options...
Swiper the Fox Posted May 22, 2010 Share Posted May 22, 2010 T04GTR said: so do we know if any rb30 rods can come with pressure fed wrist pins? i only ask cause of a very tough 26 i seen stripped, was drysumped and the little ends were all f**ked. one had punched the bronze out of the rod and had hammerd the piston pin hole in the piston to the point bits of piston were squashed out like the little end.. to much tune-up there mate. hi again...like ships in the night Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5248480 Share on other sites More sharing options...
NXTIME Posted May 22, 2010 Share Posted May 22, 2010 T04GTR said: so do we know if any rb30 rods can come with pressure fed wrist pins? i only ask cause of a very tough 26 i seen stripped, was drysumped and the little ends were all f**ked. one had punched the bronze out of the rod and had hammerd the piston pin hole in the piston to the point bits of piston were squashed out like the little end.. Was Herman driving it? Link to comment https://www.sau.com.au/forums/topic/319756-rb30-block-modifications/page/2/#findComment-5248500 Share on other sites More sharing options...
