Hey,
I noticed that after quite a spirited drive, the next morning the car was dropping to 200rpm when clutching in to come to a stop and then reving back up to 750rpm. Then once idling the car would feel a bit rough.
Had a poke around the engine bay and saw this :P
Injector no.1 (the one closest to the radiator?) seems to be covered in dirt and I can see yellow stains around the plenum.
Being at the front, it would no doubt pick up dirt coming through the car, but just want to confirm this aint no normal dirt build up? :P
I put in the injectors about a year ago and had them flow tested and new seals.
Would this be related to my near stalling when coming to a stop and then a rough idle? Its not as rouch as a disconnected cylinder, but you can feel it sort of hunting.
Would this be injector leaking? Or the seal? Or not pushed in enough?
Thanks
https://www.sau.com.au/forums/topic/319772-leaking-injector/
i think the stalling issue may be more caused byt the IAC than the injector, but i could be wrong. the yellow could be a bit of spilt oil from an oil change or something like that.
ive stripped down the IAC and gave it a proper clean thats why im not leaning towards it.
IAC controls the air flow in the air/fuel mix. Im thinking that if the injector is leaking, thats causing problems on the fuel side of the air/fuel mix which should be similar to a IAC problem?
On the old R31 (injector leaks are common) yellow around the injector was a sign of a leak, and it idled poorly / did not accelerate well.
I would clean it and then see if it leaks again after that...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
