just found this thread.
i noticed a bit of pressure drop especially in 1st/2nd, nothing alarming, but thought it odd.
those that have contributed to this thread a while back, how are you guys getting on with filling it to where you have??
on a stone cold engine, where is your oil level on the dipstick?
on a warm engine, say after 10-15mins after shut down, where does it sit?
im on a stock sump, jun pump, tomei baffle and head restrictor, i filled to just above the H.
but going by this thread, seems it may want to be closer to the hump than that.
ill put an extra 0.5ltr in and see what happens, cant harm anything a little extra oil on a pump like the jun.
  • 1 month later...
  • Replies 53
whats to question?
i run a stock sized SUMP, and an uprated JUN oil PUMP
(not sure if you read it as stock pump and jun pump?)
anyone care to let me know how there doing running a bit more oil with your setups?
Edited by jimBNR32
I would say that they would be running more oil because they are smart. If you are running a stock capacity sump with a higher flow oil pump and you go to the track, I think that your pump will drain your sump. Hence, bigger pump = bigger sump
whats to question?
Piggaz was doing track days with an overfilled sump with no problems
he had a Jun baffle though and his N1 pump (that is no longer serviacable might i had :D) has a bit less flow then you
i ran around the streets for 6 months with 400RWKW and a JUN pump on a stock sump with no problems... Filled the sump to 6L
420rwkw+semi slicks+ track use...
it needs to have a baffled sump.. overfilling works to an extent but i properly set up sump with baffles and trap doors is the second best thing after getting a dry sump
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
