Hey guys,
FML Story: Last night I was leaving Crown with a couple of mates and as I'm reversing out of my spot one of my mates in the back asked me a question. I look in the mirror and answer him and clip one of those concrete pole things..Don't know how so much damage could have been caused by going like 2km/h..
Sucks when my first accident ever is something so stupid that could have been avoided by paying more attention...only myself to blame.
Anyways, now I need just a stock R33 front bar, drivers side front panel and a drivers side headlight so if anyone is wrecking an r33 or has these parts for sale please pm me. I'm in the Eastern suburbs.
Also, some good panel beater recommendations would be handy. I have done a search on this and found a lot of recommendations for DT Panels so i'll probably hit them up.
Cheers guys.
https://www.sau.com.au/forums/topic/319869-stacked-the-33/
"Sucks when my first accident ever is something so stupid that could have been avoided by paying more attention...only myself to blame."
At least its out off the way now! No longer a virgin....look on the bright side...its minor and fixable, no one got hurt and the first accident jinx is gone!
Dr Drft...
https://www.sau.com.au/forums/topic/319869-stacked-the-33/#findComment-5223163
hey chris, did the headlight actually come out and smash? or is it just some bracket broken that holds it?, as others said you should be able to find the parts pretty easy and get Vu to spray em and fit em, if need be.
look on the bright side, your front bar was needing a respray anyway.
https://www.sau.com.au/forums/topic/319869-stacked-the-33/#findComment-5225759
Yeah just the plastic bracket thing broke. I'm not taking it to Vu, he didn't reply to my email yesterday and I wanted it fixed asap so I took it to a place near my house with a decent name. Should be getting it back on Friday...
And yes, it did need a respray so should look good at the end of it all
https://www.sau.com.au/forums/topic/319869-stacked-the-33/#findComment-5226330
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
