Why don't you think the airbox counts as an intake mod?
The rules state, only one intake mod is allowed. If you've changed your cooler, you must have the standard airbox. Granted it might be harder to dick you for it given it's an airbox, but if a cop wants to be an ass about it he/she will get you for that IMO.
https://www.sau.com.au/forums/topic/320395-arc-airbox/#findComment-5229867
i've got a trust cooler on it.
Isnt it still class as a airbox tho? so can still have 1 mod to intake (cooler)?
Is it factory? No.
Answers the question :P
Rest is here in the first page of the EPA/RW thread.
http://www.skylinesaustralia.com/forums/Ep...Th-t156269.html
https://www.sau.com.au/forums/topic/320395-arc-airbox/#findComment-5229929
an arc airbox if f**king awesome dudes.
definaely worht the cash i spent getting mine. i have had a few different intake setups (stock airbox with upgraded panel filter, apexi pod on a 3 inch metal intake pipe etc) and the arc is the only one which u actually notice the difference over the whole rev range it is more responsive.
ive been pulled over many many times with it and never had a problem however petit is another story lol
https://www.sau.com.au/forums/topic/320395-arc-airbox/#findComment-5235800
How much power are you after, in my research i have found that the standard gtr airbox is good for 300awkw any way (some say closer to 350).
Ive got 350kw. Thats all im after, no need for anymore, just want cooler air going in. With the bonnet im looking at it has a vent right where the arc box has intakes.
https://www.sau.com.au/forums/topic/320395-arc-airbox/#findComment-5238600
Legally expensive :ninja:
But worth it if you have the dosh...
Actually, near impossible to tell unless they go ripping your front bar off, but it's still technically an intake modification replacing the standard side mount with an ARC...
https://www.sau.com.au/forums/topic/320395-arc-airbox/#findComment-5239689
Not that I don't believe you but I'd really like to see dyno graphs to back that up. Not being a smart ass here, actually being serious - do you by any chance have any? I've often wondered just how much difference, if any I'd see.
ARC coolers are rad, I had one (and still have a damaged but air tight one for an R34 GTT in my roof). Not sure what you mean about legal, unless you mean the factory mount replacements, which yeah - you'd get away with.
https://www.sau.com.au/forums/topic/320395-arc-airbox/#findComment-5239721
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
