Car was imported from Japan 8 months ago with 37,000kms and now sits at 41,000kms. I'ts in very good condition and drives like a dream. The car has been modified and adjusted to perfection. It's speed and handling is amazing and will not disappoint any interested buyers. Reason of selling is that I must go to work abroad and my sister needs a car to drive while im gone and i don't think she'll like that twin plate or vice versa =P
---$25k---
Am up for swaps so show me your interests, need this gone guys!
The car has just been serviced with
- Iridium Spark Plugs
- Bendix Brake Pads
- Nissan Fuel/Oil Filters
- All Top Quality Oils
- New Nismo Super Coppermix Clutch
- Brand New 265/35 18" Tyres
Specs are as follows.
Braking & Drivetrain:
18" White Volk/Rays TE37 Wheels
Aftermarket Nismo Brake Booster
Nismo Super Coppermix Twin Plate Heavy Duty Clutch (Just Fitted 1 month ago by HyperDrive, Cost 4k for Clutch + Install)
Nismo Super Lightweight Flywheel (Also Just fitted)
Adjustable Tein Superstreet Coilovers
Engine:
Cusco Engine Strut Bar
Twin HKS Air Filters
Greddy/Trust Intercooler And Piping
ARC Oil Filter Relocation Kit
ARC Oil Catch Tank
HKS Oil Cooler
HKS Camshafts
Nismo R33 GT-R N1 Turbos
Factory Nissan ECU Rom Chipped and Tuned in Japan
Nismo Radiator Air Diversion Plate
Blitz Nur Spec 4" Full Exhaust System
All Quality Braided Oil Lines
Adjustable Nismo Fuel Pressure Regulator
Interior:
Driver and Passenger Recaro Racing Seats
Twin Defi Gauges (Boost + Water Temp)
Defi Multi Link Control Unit 2 (Gauge Controller + Data Logger)
Nismo A-Pillar Gauge Holder
Carbon Fibre Cluster Surround
Carbon Fibre Factory Din Gauge Surround
Nismo Shift Knob
Greddy/Trust Turbo Timer
HKS EVC 4 Electronic Boost Controller (0.8 Bar Low Boost 1 Bar High Boost)
Apexi Exhaust Valve Controller (Pull for stock silent exhaust note or when you want to avoid any attention)
Momo Steering Wheel
Yoshio Factory Water Temp Monitor
Sony MP3/CD Deck
Body:
Stage 21 FRP Bonnet on it's way from Japan as the original had a few deep scratches
Nismo N1 Bonnet Lip
Nismo Front Bar Spliiter
Nismo Rear Bumper
Nismo Rear Strut Bar
Led Tail Lights (Brake + Indicator)
Edited by Richy08
https://www.sau.com.au/forums/topic/320611-r33-gt-r-vspec-41000kms-370hp-atw/
Hey mate,
Would you be interested in a swap for an 04 350GT? It's red, manual, sunroof, brembo's
20 inch wheels, aftermarket exhaust, nismo rear spoiler and 44kms. My number is 0425 706470.
Cheers
nice GTR - good luck with the sale.... I am looking at selling mine soon... Just wanted to know where you got your front lip from, I am looking to replace mine prior to sale....
Thanks....
Oh, and free bump...
Thanks....
go the front lip from JS Auto imports
http://jsai.com.au/index.php?page=shop.pro...t&Itemid=29
Hey would you be interested in A swap and cash your way.
R33 gts-t and 12g you way.
Model
R33 Gts-T
Specs
Engine: Rb25Det
85000kms
KKr430 turbo
High Mount Stainless Manifold
38mm Wastegate
HKS AirFilter
Front Mount Intercooler
HKS HI Power Turbo back 3 1/2" exhaust system
Bosh 044 External Fuel Pump (in tank)
Iridiums
HKS Turbo Timer
Turbosmart Manual Boost
Bodywork:
Resprayed Into BaySide Blue R34 GTR Blue
Trust Front Bar
Trust Side Skirts
Custom Rear Bar
GTR 33 Wing
Stereo:
Alpine Cd player MP3
Pioneer Speaker
600 Watt x4 Amp
Subs X 2
Driveline:
Exedy 5 puck Clutch
Adjustable Coilovers
Edited by KF-
  • 1 month later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
