hey guys i have a crashed r32 gtst wreaking. most panels are f**ked but still has good doors boot rear bar and rear pods. most of the car is for sale apart from front brakes.
in devonport
motor, box, loom, computer, fuel pump and anything else to do with the motor for $1400 ono
indicators in good nick? pics of whole car if possible?
how much for box seperate?
drives side one maybe i'll have a look. i'll put some pic up soon and i'd rather keep the box with the motor at this stage mate but i do have a spare one at my place what would you be looking to pay for one ?
in devonport
bonnet is all good has no dents. black $70
LH side door has no dents $40
RH has a dent near door handle $20
door window glass $25 each
rear window $40 (pull out your self)
little side windows $30 each (pull out your self)
boot lid has small wing on it $50 (no dents)
tail lights $20 each
rear bar $40
rear pods $40
rear brakes $50
full interior just ask for prices on what you want. (has not got center console bit around gearstick)
pictures will be put on tomorrow for any thing else not listed pm me for prices thanks
Shot gun rear pods, taillights (if they come complete with surrounds), rear bar (if complete with reverse lights), fuel filler lid, and also what condition are the door/window rubbers in if perfect I'll have those too and also front windscreen moulds/surrounds the plastic bits. Cheers.
Pm sent.
Edited by krayzie32
Pm sent.
Edited by krayzie32
I'm down Hobart mate, can you post please? or pm me your number & i will call you? Or you can contact me on 0419525562..can I also get the 8 bolts i think it is with them..Bolts that hold hinge to bonnet and bolts that hold hinge to the wall
Edited by Baz_R32
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
