N/A 33 Posted May 18, 2010 Share Posted May 18, 2010 sorry guys forgot to ass this to my last post. after my car has warmed up on ocassion at idle the revs play up a little, i have reason to beleive this could be my 02 sensor just wondering where i can get my hands on a real one and not a universal fit one, thnx for the help Link to comment https://www.sau.com.au/forums/topic/321133-02-sensors/ Share on other sites More sharing options...
R34 -_- Posted May 18, 2010 Share Posted May 18, 2010 (edited) Check spark plugs and coils. o2 sensor only changes the amount of fuel injected and is usually associated with ppl complaining about fuel economy not idle/misfiring Edited May 18, 2010 by R34 -_- Link to comment https://www.sau.com.au/forums/topic/321133-02-sensors/#findComment-5240523 Share on other sites More sharing options...
N/A 33 Posted May 18, 2010 Author Share Posted May 18, 2010 Check spark plugs and coils. o2 sensor only changes the amount of fuel injected and is usually associated with ppl complaining about fuel economy not idle/misfiring its not a missfire the idle just doesnt settle, it fluctuates between maybe 500 to 1500 rpm without me touching the accellerator, also when hot it occasionaly has a backfire which i thought would be from over fueling Link to comment https://www.sau.com.au/forums/topic/321133-02-sensors/#findComment-5240539 Share on other sites More sharing options...
Jezza-gtR Posted May 18, 2010 Share Posted May 18, 2010 Try a TPS sensor mate. Also.. have the car idling, disconnect the TPS to see if it returns to normal, if it does, that's your problem. Link to comment https://www.sau.com.au/forums/topic/321133-02-sensors/#findComment-5240826 Share on other sites More sharing options...
mad082 Posted May 18, 2010 Share Posted May 18, 2010 could also be the idle air control valve (IAC). this often causes a lumpy idle when it is a bit fouled up Link to comment https://www.sau.com.au/forums/topic/321133-02-sensors/#findComment-5241578 Share on other sites More sharing options...
N/A 33 Posted May 19, 2010 Author Share Posted May 19, 2010 could also be the idle air control valve (IAC). this often causes a lumpy idle when it is a bit fouled up thanks for the help guys ill give both of them things a crack and see what happens Link to comment https://www.sau.com.au/forums/topic/321133-02-sensors/#findComment-5242610 Share on other sites More sharing options...
