zebra im not looking at a new ecu to make more power, 340klw at the wheels is plenty for what im doing with the car im just after better drivabilty i feel AFMs are just not consistant at giving accurate readings for the ECU which results in the car feeling sluggish at times,and yes they are new items.
choyda did yo have a powerFC before u got the vipec?
keep us updated on how your car turns out matt
cheers for the feed back guys!
Fair enough, Although many people say they loose drivability going MAP based with GTRs, they are bit tempremental in regards to where the MAP sensor is plummed into.
Hi,
I had the stock ECU and changed to Vipec to suit my mods. I did have a Power FC (no d-jetro) on my GTT. Certainly with the vi-pec the car drives like its standard (smoothness wise), seems to cope with different temps, cold starts, humid days much nicer than my Power FC did.
The tune also gives me surprisingly good fuel economy for a GTR anyway. I didn't have great economy in by GTT... could have been the tune though.
Damien
Not using the TPS as a correction with a MAP sesnor.
Guilt-toy is the v88 a plugin? if not do i need the v88 or will the v44 be fine?
V44 will be fine for a road car...same as we run in our street/circuit gtr with over 450awkw.
The only advantage of running a V88 is its direct fire ignition and the fact you have heaps of inputs and outputs for control/sensors etc.
Interesting, I need to go for a drive in a Vipec car that has had 1-3 hours of tuning. Be it Motec, Autronic, Microtech or Wolf (Never been in a car with a ViPec) the MAP sensed and tuned cars traditionally seemed to always require more dyno and road time to get the tune to the point where you got the drivability of the AFM Pfc and the fuel economy.
I do believe about 75% of it is in the tune and 25% of it the ECU. So if the ViPec and some of the softeware allows it to be quickly tuned and accurately tuned then that is a big bonus.
I have a Vipec V44 plug-in on my Stagea 260RS (R33 GTR engine). I also had the problem with the aircon clutch relay, but it's easy to fix. I believe the next runs of ECUs will have a fix for this anyway (if it's not out already). Either way, it's no biggy. Yeah, you don't have to wire in a wideband O2 sensor, but there are heaps of features you can access when you do. I just picked an Innovate one for $200, so will be wiring that in soon to trim my tune a bit more. I went from stock ECU to Vipec and it really does drive as smooth as stock. Mine has been tuned as mentioned above. 2 maps, 1 with TPS vs RPM and the other MAP vs RPM.
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
