hi all.. I"ve been having some issues with my r33 gtr front bumper, got a new one, a series 3, looks damn nice.
ive mounted the bar up, and bolted the back screw of the bumper the screws into the guard, that one is small and easy.
Im not sure how to bolt this next part up, its a part on the side of the guards, and its the closest bolt to the front sdie of the headlight. its like a 1cm sclip of some type that goes throw the larger hole on the side bumper guard area. Does anyone know how this clips on or bolts up?, ive never seen a clip thing like this.
I have a red circle around the area.
also, my bumper did not have holes to bolt or clip into the reo bar, the part were the grill is.. i have circled these holes on a bumper picture i found on the internet. are these originaly there from factory?,, if so, i should make holes i guess... thanx a heap if some could lend me a hand, i dont want my bar following of sometime :D..
https://www.sau.com.au/forums/topic/321415-someone-with-a-r33-gtr-help-me-out/
hi, yeah, grill is out, and just the bumper is mounted up. i just cant figure what type of clip or screw goes in this side front connection, it comes of the guard into the larger hole on the bumper.. i have the grill holes for the grill at the back of the reo, and i do have 3 smaller holes down for that, but the bar doesent reach them, and i have no holes on the front top of my bumper to mount onto reo. just feels un safe.. thanx
it should be the same as a gtst.
Generally its a 10mm bolt with a phillips head on it. where it screws/bolts into there should be a plastic insert for the thread to grip
how about an actual picture of what your talking about rather than one you cant actually make out what your looking at :(
Edited by gotRICE?
true.. thanx for the advice.. ill jusdt wait a couple of days until i pull the bar off again and i will take pictures.. i was wanting to know so i could finished the bolts off without taking apart, putting together, then apart when i find out :D.. thanx.. see whati can do :)
found a picture on a r34 diy of how to remove the bar..
its the blue circle.. its a dark clip and hard to see.. mines the same but in white.. wanting to know what goes on this clip once it pokes through the bumper hole
thanx so much.. i was think it might be a screw with a larger head.. because it needs to somehow keep this clip through the biggest hole on the bumper from coming out.. thanx again.. ill try a 10mm and see how it goers :P.. thanx 4 your time hey
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
