Hello everyone,
I have an R34 GTT with open air filter and 3" cat-back exhaust system. Thinking of adding a HKS EVC-S boost controller. Will that work just fine with original ECU or will the engine go dry (air/fuel mix)?
What if I install a downpipe and race-cat as well? Will it still work fine?
Thank you very much,
Karl from Stockholm, Sweden
https://www.sau.com.au/forums/topic/321498-how-much-can-original-ecu-handle/
Obviously it depends on how much boost you run. If you want to run 12psi (max recommended for stock turbo) you may run into problems. First get the full turbo back exhaust then look into a Nistune chip for your ecu.
Yeah, 12psi is what I was thinking as boost level. So you mean that I should get a downpipe and de-cat/sport-cat and a Nistune chip before I buy a boost controller?
As I live in Sweden, and Skyline were never sold here, Nistune chip is quite hard to find. Can you recommend a web store that sell Nistune chips?
After installing the chip a re-map of the ECU is needed, right?
make sure you have a full turbo back exhaust and you can run 12psi just fine. the ecu will manage it fine without going a nistune, although a nistune would make it better. would be wise to also get a front mount intercooler as well if you don't already have one.
keep it to 12psi max and the stock ecu will have no drama's.
if you can afford to o nistune, and dyno then it will be HEAPS better tho :)
the r34 SMIC is also an easy option and can flow up to ~200rwkw
You wont lean it out, once you max out the ecu it goes into rich and retard mode, so once you hit the limit you will be losing power, also one you hit that limit (around 200rwkw) you will also need new injectors, afm and fuel pump, your next step should be a full 3" exhaust, if you have a 3" cat back then just buy a 3" dump (i have a 1 piece split dump that you can get from just jap in the traders section) and 3" cat or if the cops are not nazi's over there buy a de-cat pipe, should do the exhaust before upping the boost tho.
Also if you dont have someone over there that can tune nistune then dont bother, go for something more common like a power fc that any decent tuning shop will know how to tune, wont cost much more than nistune.
Edited by W0rp3D
Thanks for the tips guys!
Will go for a new front pipe and 3" cat and FMIC first, it seems to be the smartest way of doing, as you say. Boost controller will be the 2nd step.
If I don't want to go for a Nistune (which is hard to find in Sweden) or a Apexi (which is so damn expensive), is the HKS FCD the best option to control air/fuel-mix?
also stock injectors, fuel pump, and afm can all flow around 230rwkw
depending on condition and what dyno you use, at 210rwkw my injectors were at 100% and my afm was tuned past its max.
can also depend on the condition of the engine as well. a stronger engine will make more power with the same amount of fuel, etc. but on a mates 33 that i did a turbo install on the AFM wasn't quite maxing out at 250kw. it was getting very close to it (high 90's %), but hadn't quite it 100% though. that was with a 3076 with the skyline rear housing running 16psi. can't remember if he had the injectors in at the time or not. i have a feeling the injectors may not have gone in until after that as the stock ones were getting extremely close to maxing as well. i'd have to go looking through the dyno thread to see whether they were on the mods list at the time of the dyno run.
The ECU's from the different models seem to be less tolerable as the years went on.
My R32 RB20DET ECU handled everything from full exhaust/fmic upgrades, 14psi on stock turbo, 12psi on 25 turbo AND in the end, a 3L bottom end.
Here's another bit of trivia.. stock afm made 183rwkw on the RB20 with no signs of maxxing. Same afm on the 30 making the same power (same turbo), maxxed out a little over 6000rpm.
things like your fuel pressure, how well the injectors are working (how clean they are, etc), etc will all affect how much power you can make on the stock injectors.
not to mention a crap exhaust, a motor that just doesnt wanna make power and a low reading dyno, which were the main factors for myne.
20det ecus seam to do fairly well with more airflow, but then again 20s need something to help them out :(
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
