Hello everyone,
I have an R34 GTT with open air filter and 3" cat-back exhaust system. Thinking of adding a HKS EVC-S boost controller. Will that work just fine with original ECU or will the engine go dry (air/fuel mix)?
What if I install a downpipe and race-cat as well? Will it still work fine?
Thank you very much,
Karl from Stockholm, Sweden
https://www.sau.com.au/forums/topic/321498-how-much-can-original-ecu-handle/
Obviously it depends on how much boost you run. If you want to run 12psi (max recommended for stock turbo) you may run into problems. First get the full turbo back exhaust then look into a Nistune chip for your ecu.
Yeah, 12psi is what I was thinking as boost level. So you mean that I should get a downpipe and de-cat/sport-cat and a Nistune chip before I buy a boost controller?
As I live in Sweden, and Skyline were never sold here, Nistune chip is quite hard to find. Can you recommend a web store that sell Nistune chips?
After installing the chip a re-map of the ECU is needed, right?
make sure you have a full turbo back exhaust and you can run 12psi just fine. the ecu will manage it fine without going a nistune, although a nistune would make it better. would be wise to also get a front mount intercooler as well if you don't already have one.
keep it to 12psi max and the stock ecu will have no drama's.
if you can afford to o nistune, and dyno then it will be HEAPS better tho :)
the r34 SMIC is also an easy option and can flow up to ~200rwkw
You wont lean it out, once you max out the ecu it goes into rich and retard mode, so once you hit the limit you will be losing power, also one you hit that limit (around 200rwkw) you will also need new injectors, afm and fuel pump, your next step should be a full 3" exhaust, if you have a 3" cat back then just buy a 3" dump (i have a 1 piece split dump that you can get from just jap in the traders section) and 3" cat or if the cops are not nazi's over there buy a de-cat pipe, should do the exhaust before upping the boost tho.
Also if you dont have someone over there that can tune nistune then dont bother, go for something more common like a power fc that any decent tuning shop will know how to tune, wont cost much more than nistune.
Edited by W0rp3D
Thanks for the tips guys!
Will go for a new front pipe and 3" cat and FMIC first, it seems to be the smartest way of doing, as you say. Boost controller will be the 2nd step.
If I don't want to go for a Nistune (which is hard to find in Sweden) or a Apexi (which is so damn expensive), is the HKS FCD the best option to control air/fuel-mix?
also stock injectors, fuel pump, and afm can all flow around 230rwkw
depending on condition and what dyno you use, at 210rwkw my injectors were at 100% and my afm was tuned past its max.
can also depend on the condition of the engine as well. a stronger engine will make more power with the same amount of fuel, etc. but on a mates 33 that i did a turbo install on the AFM wasn't quite maxing out at 250kw. it was getting very close to it (high 90's %), but hadn't quite it 100% though. that was with a 3076 with the skyline rear housing running 16psi. can't remember if he had the injectors in at the time or not. i have a feeling the injectors may not have gone in until after that as the stock ones were getting extremely close to maxing as well. i'd have to go looking through the dyno thread to see whether they were on the mods list at the time of the dyno run.
The ECU's from the different models seem to be less tolerable as the years went on.
My R32 RB20DET ECU handled everything from full exhaust/fmic upgrades, 14psi on stock turbo, 12psi on 25 turbo AND in the end, a 3L bottom end.
Here's another bit of trivia.. stock afm made 183rwkw on the RB20 with no signs of maxxing. Same afm on the 30 making the same power (same turbo), maxxed out a little over 6000rpm.
things like your fuel pressure, how well the injectors are working (how clean they are, etc), etc will all affect how much power you can make on the stock injectors.
not to mention a crap exhaust, a motor that just doesnt wanna make power and a low reading dyno, which were the main factors for myne.
20det ecus seam to do fairly well with more airflow, but then again 20s need something to help them out :(
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
