18 x 10 CCW C10 wheels
anodised black
seems to be reasonable brake clearance, more than 6mm at its tightest
offsets difficult to judge whilst suspension is not under load but should be aggressive without sticking out too much by my estimates, fingers crossed for when the slicks are mounted and the car sitting at ride height.
https://www.sau.com.au/forums/topic/321550-complete-custom-wheels/
hey John,
they are 10 inch wide with 6.6 inch backspace - bit rough to convert but maybe +27mm??
welcome to try them on anytime if thats close :cheers:
though with the times your car is getting already i dont know if I should!
hmm that offset might work :D but might have to come and try it out one day
can u weigh the wheel as well ? cheers
mind if i ask how much they are ? and where to get them from ? pm me if u dont want the world to know the price
as i found out at superlap, u can never have enuff tyre on the road
offsets works well up front. will be tucked in at the rear. I reckon I will need a 15mm spacer but will wait and see.
plenty of brake clearance, tried to demonstrate with backlight as I know many of you are interested
thanks Duncan.
only went with this set up after you had done all the hard work trying various wheel/tyre combo's
i would recommend the CCW for anyone who is interested in 18 inch track wheels and is concerned about brake clearance
  • 3 weeks later...
The new wheels and 27/68/18 second hand michelin porsche cup slicks worked well today. As did all the other mods Trent and the boys down at Mercury have been frantically finishing off for today. more on that some other time.
here are some pics of the wheels on at the track. Just over 3 degrees camber, about 15mm lowered. no rubbing.
55.67 on the sprint and 58.12 on the Clubman at QR
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
