Exhaust leak rectified, turbo sounds normal again but responds even faster.
Starts spooling as early as 2000-2200 and tonight it regularly saw 10PSI at 3000rpm.
Doesnt FEEL like a DE+T but might very well be. Must run a compression test on it ASAP and find out....
Had a hard time trying to get a video of tacho, boost gauge AND not crashing, all at the same time...but will get around to it.
14 PSI, sweet.
But then.....
Replaced every hose clamp in the entire car with new aftermarket ones. Took me a while but looks neat and no more blowing off intercooler pipes.
Next I painted the heatshields.
Currently not running AGAIN due to brand new Bosch 040 overheating after any more than 15 seconds of use. Trying to rectify :\
Still not fixed :( Idled fine for 30 minutes, got out of my suburb and onto the highway and started all over again. Had to let it cool down 5 mins at a time every 2-3 km (without going over 2500rpm) to limp it home.
Pic I snapped while waiting for it to cool down again.
They do but too wide for the open centre diff to do skids in. clutch kick any revs below 4000 and it' just bogs down and launches, even when it does do a skid (ie forced first gear into 90 degree corner) suspension flexes up, demon camber comes on and skid is only 2inches wide (from a 9 inch tyre).
Definately need to roll guards, slam it some more, wind out camber, and fit LSD / mech.
UPDATE:
Car fixed, cleaned fuel tank today and chucked in another 500hp pump, run's great, again, for now.
:D
Turn one wheel in a direction, opposite wheel turns opposite direction. Open Centre FTL
I know most 20DE Ceffy's had LSD but this one was indeed a 20E when I got it.
Got an LSD at mate's place, still deciding if I can be f**ked doing the shims before I just top up oil and chuck it in.
Took her out with some Perth guys for a bit of a photoshoot. Mate does it as a hobby.
http://www.facebook.com/pages/RM_Photography/109188375789078
http://www.facebook.com/album.php?fbid=140162859358296&id=109188375789078&aid=15232
Not much else in news at the moment. Few little things need doing, have racked up over 800km in it since new engine and still ironing out all the problems.
Cracked the $1000 mark of materials that I've spent reviving the halfcut motor to where it SHOULD be. Almost ready to lean on the car as a daily again. Has been good fun to drive around though, and rather interesting finding ways to get it going every time it breaks down 40+ km from from.
LOL I kept telling you it was a bunky POS but you insisted on taking photo's of it :P
non-ABS stuff? dunno, whenever? Fix Jess's car and take a night or two off to cool down. LSD has been sitting here for ages, gotta order some shims for it. I'll might chuck it in as is when the single piece driveshaft arrives - a bit easier that way. Then shim it later?
looking gud nic, whats the light in the shutter speed pic i cant tell?
i got 3x 1.20 mm shims, installed two on the spider gear side and one on the other side and put it all back together. need to get around to installing it on the car when i get some free time.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
