Looking for some tech advice from all you Sky boffs out there.
I was heading home just now and the car has been absolutely fine, I arrived at a set of lights, shifted to second and before I stopped, depressed the clutch.
Now, as I went to shift to Neutral, (clutch depressed, car stationary) it was very difficult to take out of gear. I took the clutch to friction point again and it was engaging normally so depressed it again and gave the stick a little tug until it popped out. All good I thought, however now, there is no resistance changing into any gear at all. And driving requires I hold it in gear as it will pop out from transition from on to off throttle.
It does this in every gear now. All gears were fine before. So I'm thinking it can't be synchos or gears as it is suddenly on all gears.
Does anyone know what the mechanism is like for the shifter linkage enabling it to lock into gear.
Any help would be brilliant.
ok, the mechanism to keep gears engaged is not the synchros (if it still goes into gear fine, they're fine) but a check ball and spring. I think that the checkball has jammed (maybe some foreign piece of gunk floating around has jammed it) the fact it was difficult to push out of gear would support this- this would have been the jamming action on the checkball. I've included some pics to show you where this is located on the box and what it looks like inside. It's accessible without taking the box out and you shouldn't need to drain the gear oil either.
Firstly take the larger bolt out (17mm) and if you look inside you'll see a spring- there is a ball on the other side of this. Pull the spring out with a relevant tool and then the ball (you might need a magnetic tipped tool)- if it's jammed then leave it. If you take the whole assembly out (by undoing the smaller 14mm bolt) and the spring is loose, it will drop into the case and you will have to take the gearbox of and disassemble to retrieve it. Don't go there. However as the ball is probably jammed you should be OK, but do check. You will need to take the whole assembly out if the ball is jammed to unjam it anyway (you will have to pry it out as it has sealant on the mating surfaces)
If the ball is scored get another one and clean the assembly from any potential crap.
Reassemble with new sealant on clean surfaces and then pop in the ball and spring.
Any queries or probs post them up.
Quick edit- where taking the assembly piece out I've said if the spring is loose it will drop into the box, I mean if the ball is loose and still in the assembly it will drop into the box, take it out first. However, I imagine this is what is stuck so if it is you won't be able to take it out and it also shouldn't be able to drop into the box. sorry to be pedantic but dropping the ball into the box would really, really suck.
That sounds right on the money! One minute it's perfect, and the next it's sloppy through all gears. Just wasn't sure how it works on these but there was no way it was gears.
Thanks so much, I haven't even got in there but this is it, no question. You're a legend.
I'll let you know when I get a chance to get in there.
Cheers bud and thanks for the pics, that really helps.
Cheers again buddy,
It looks to me that the entire assembly retains the ball and spring, so if I take the entire assembly out and get the ball and spring moving again, it should be right, does that sound right?
thanks again mate.
Don't take the assembly out until you've tried to take the ball out. The ball is not retained in the assembly on the inner side, as it pushes against indents in the striking rod (which moves back and forward as you move the gear stick back and forward). You should still have side to side resistance in the gear shift lever as this is a different spring. If the ball isn't stuck and you don't take it (the ball) out before taking out the assembly it (the ball) will fall into the gear box case. And then it requires disassembly to retrieve. Yuk. If the ball is stuck you won't be able to get it out so it shouldn't fall in. You'll then need to remove it (the ball) from the assembly and clean it all up to work properly again. I know I'm repeating myself but as I can't be absolutely sure the ball is actually stuck, take this precaution as you don't want it to turn into a gearbox-out-of-the-car scenario.
That's a great explanation thanks, I can picture it now with your description.
So I can see now how if there was something caught where the ball would normally be pushed back into the assembly, it may have given me resistance. Then as I forced it out of gear (the ball into the assembly), it became jambed inside the assembly and now has no contact with the rod as the spring cannot push it back out on its own hence the gear selection feeling very loose.
That's brilliant! I just went out and got under there and i just can't get to it easily with the car just on stands. Your pics were very helpful as you can't see it from below, but going by your pics, I know exactly where it is. But I can't get my arms at the right angle.
i'm going to have to get the thing on a hoist I'm thinking.
thanks again, if you have any tips on accessing this, throw 'em at me.
thanks again.
So I've popped the car up and had a look under and I reckon you'll need to d the following to get decent access. Remove clutch slave cylinder, remove front drive shaft. Then you might like to drop the box down by doing the following- undo the driveshaft at the end of the transfer case (you can leave hydraulic line attached, just don't let it bear any weight of gearbox), undo exhaust at cat, with a jack or similar support under and of box undo the g'box crossmember then gently lower it down. You should check the fan clearance on the radiator shroud when you do this, but it's the only potential issue I can recall. If you have an aftermarket front pipe and need more room for drop then you can undo the steering plate cover that is directly under the front pipe, this gives a bit more room.
You'll probably have a small issue getting the assembly out (after getting the spring and possibly the ball out). Having taken the smaller bolt out put the larger one back in but leave enough of it sticking out to use a screw driver or similar behind it to pry it out- use the box case as a leverage point.
A hoist will make this far easier, but if you like a challenge it's possible to do on jack stands. Just have your swear jar within easy reach.
Edited by doo doo
haha.... thanks mate.
Swear jar's already full and I haven't started yet.
Great description and thanks so much for having a look.
You're right, front shaft and slave will have to come out as a min. I have a mate with a workshop so I'll try to get it on the hoist as I can see me becoming very loud trying to do this when i can barely fit my face under the car.
Thanks again, I'll let you know how I go.
Well, cheers for all the info Doo Doo.
Got to the part, was frightened as hell that the ball was going to drop into the box, didn't make sense that it would though.
Came out, ball was jambed inside the cylinder, looked like the ball had worn a flat spot and that last time, it turned and the flat area helped jamb it in the assembly. So it came out together.. brilliant!!
Replaced the ball with a new one and she's wonderfull again.
Cheers for the help again.
  • 2 months later...
if the ball is stuck then yes it shouldn't drop into the box, but best to be absolutely certain first. It might not roll out as it's sitting flat, but using a magnetic tipped tool or similar to try to draw it out should tell you whether it's stuck enough not to drop. I imagine a gearbox shop or nissan will have a replacement ball.
The ball runs into indents in the single shaft that moves back and forward for all gears, so yep, a stuck ball or spring will affect all gears in the forward/back (ie 1-2, 2-1, 3-4, 4-3) by letting them slip out of gear (The stick will still move from side to side no probs as this is a separate pair of springs)
If it's only happening in a single gear it is more likely a synchro hub issue than a selector issue. Synchro hub issues are highly symptomatic on deceleration or going downhill.
Doo Doo said in the 2nd post that the synchros dont hold gears in?
i thought the detents (little balls) held the selector fork rod in place once fully engaged.
so it might be possible as doo doo said,that the detent as shown in his pics might be getting stuck at certain sections of the selector rod.
Does it also happen in 2nd gear? You won't usually produce the same condition in normal driving of backing off in 2nd but try it and see if it's the same deal. The indent on the striking rod for 2nd is the same one for 4th and reverse. If you get the same sort of result then it might be related to the ball not locking into that indent properly. You can still take the ball mechanism out (with the previously mentioned precautions as the ball is probably not stuck) check it and clean it up and then see if the problem persists.
Edited by doo doo
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
