Hey Everyone,
I have for sale Twin GTR Group A Racing Turbo's which I brought around 2 months ago (yes the same turbo's used on the Gibson Motorsport GTR). These turbo's where going to be used on my 1993 Ford Falcon 4.0 6cyl as a Twin Turbo setup which previous used Twin GTR N1 R33 Turbo's. I have decided to not complete my project car and I have no need for these turbo's anymore.
I am not interested in making money only breaking even, I paid $1250.00 so naturally I want $1250.00.
NOTE:
These turbo's have no Garrett ID Tag, (I don't know even if they come with a TAG being a racing turbo). I purchased them from a 65 year old man who had 3 sets of GRP A Turbo's, Genuine Garrett 800mm Tube and Fin intercooler cores, plus many other Nissan racing parts. As he was heavily involved in motorsport years ago with the old R31 Skyline and R32 GTR (Gibson Motorsport). I don't have a lot of information except that the Turbo's are rated to 2 bar, they have been rebuilt as some stage in there life and are around 350-380hp each and have made 500rwhp on a RB25 @ 18psi.
General Specs:
Steel wheel
360 degree thrust bearing
Front housing markings, Garrett A/R .60 M24
Rear housing markings, Garrett .64 696-2 T695
Inspections welcome. Please contact me anytime.
Regards,
Matt
0410 101 096
https://www.sau.com.au/forums/topic/321978-fs-qld-gtr-group-a-racing-turbos/
GROUP A 1250 the pair ... 2nd hand right, their clean some1 buy them !
hey these are bolts on right ?? even the water and oil feeds ? just 60/64 housing steel wheel, bearing type ??
Yes Group A Turbo's $1250.00 the pair
Yes 2nd hand
Yes bolt on to stock manifolds, dumps, water and oil lines.
Yes steel wheels Turbo's
360 degree plan bearing so not ball bearing
Do you have part numbers?
Sorry mate this is all that I have.
NOTE:
General Specs:
Steel wheel
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
