  • Replies 103
Just thought this would make for some interesting convo :wassup:
ill start: I went to Tecoma primary- And Upwey high school :headspin:
Oooh close, I'm
Primary - Fairhills Primary - Ferntree Gully
Secondary - Fairhills High School - Ferntree Gully (AKA Fairy Land)
Bahahahahaha
Nothing is woggier than a sweaty Marchole!
I remember punching the living shit out of some guy from marcellin during one of the big fights at shoppingtown.... Then some prick hit me :) lol memories!
You were a shoppo hanger? bwahahaah! Did you get the .30c meal deal at maccas (0.30c cone and a free water) so you could 'hang' legally? :)
no ****ing shit?! :headspin: :headspin:
i went to both those schools!! Tecoma for primary, and Upwey High School, and for about 20 years i lived in Belgrave! My mum still lives up there. I only left Melbourne about a month ago for up here, but went up their regularly. Thats freaky.. You would have only been a couple of years below me too. I bet you know people that i know :) hey do you Nathan Haley? I'm friends with his brother. Tanya Houston? Kristie Davies? Any of those names sound familiar?
oh, and i went to Monash Clayton for one year (sucked), and then Swinburne Hawthorn for 4 years or something.
okay, I'm adding to this list coz I wanna get to know a few of you guys before I get my 'line later this year.
Primary: New Gisborne
Secondary: Braemar College
Tertiary: Melbourne Uni
New Gis and Braemar are all kinda country schools, so dun worry about not knowing them :wassup:
red hill primary -> padua college -> peniunsula grammar -> geelong grammar
Osborne Primary - Mornington
Mornington H.S.
Good to see there are some people from the mornington peninsula on the forums!
I went to:
Mt. Martha Primary
Woodleigh School
Monash Uni and still there for another 2 and a bit years...
Wantirna Heights Primary
Ferntreegully North Primary
Bayswater West Primary
Fairhills Primary
Knox Technical School
Swinburne Croydon
and spent a year short coursing at Alabama Uni ,Birmingham,(AL,USA)Roll Tide.
You were a shoppo hanger? bwahahaah! Did you get the .30c meal deal at maccas (0.30c cone and a free water) so you could 'hang' legally? ;)
lol i caught the bus home a couple of times via shoppingtown!
I was never a shoppo hanger, i was only at whitefriars till year 8 so my shoppo hanging wasnt cultivated yet...
Do you remember the guys from both Marcellin and Whitefriars who used to get changed into their 'kappa' snap pants after school to hang at shoppingtown????
Bahhahahaha classic.
Guest
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
