yeah its kinda a major no no . like big fines . really big . like 5 figures big .
there will be a nipple on the pipe somwehere that has what looks like a tire valve cap on it . or one of the lines off or unbolt them
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5253283
legal way: drive to local aircon place. ask them to degas aircon. hand over keys. come back after however long they tell you.
the job itself should only take about 5 mins, but depends on how busy you are. as to how much they charge i wouldn't know, but it shouldn't be too much.
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5253341
shouldnt cost much, they will suck it out with a recovery pump into a bottle of waste R134a Refrigerant.... if your planning on removing air con lines and such you will need a new reciever drier when you put it all back together
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5254052
ahhh shit lol.... it been to long since ive been taught air con systems
I googled it for you cause I wanted to remember what it does as well...
RECEIVER-DRIER
The receiver-drier is used on the high side of systems that use a thermal expansion valve. This type of metering valve requires liquid refrigerant. To ensure that the valve gets liquid refrigerant, a receiver is used. The primary function of the receiver-drier is to separate gas and liquid. The secondary purpose is to remove moisture and filter out dirt.
Air Con Information
So basically its for the secondary reason that you must replace it because it will absorb alot of moisture from atmosphere when it is disconnected from the system.
Edited by 89CAL
https://www.sau.com.au/forums/topic/322086-de-gasing-ac/#findComment-5255873
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
