ok, i have an R32 GTS-T and a full 3 inch exhaust with a cannon. i have seen my mates GT-R make meter long flames and just wondering why mine doesn't?
i know it's to do with unburnt fuel and a hot exhaust igniting it, and mine makes some fery loud pops! but i've just never been able to get a flame! i have had mates repeatedly rev it to see... some pops are really loud cracks and some are deep thuds. anyone know anything about this?
https://www.sau.com.au/forums/topic/322087-why-no-flames/
get a b r limiter , they are like the mad core . the flames make your way car faster . but it drifts weird if your exhaust isnt in the middle . pull the exhaust off at the dump pipe and itll make it do wheelies
+1 but my car did back flips instead of wheelies... i think i pulled to much of the exhaust off
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5253297
all GTR's need is a gutted cat or de-cat and you will get flames.
mine lets flames out a fair bit with de-cat but as others have said over time the rear bar gets black shit over it which does come off but is annoying. Will probs be getting 3M clear film/sticker for rear bar protection or just chuck a high flow in soon.
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5253305
Step 1: remove cat
Step 2: turn off the decel fuel cut on computer
Step 3: pay ridiculous amounts of money in fuel to burn rear bar
you forgot to add in step 4, which is "say goodbye to the exhaust wheel of the stock turbo as it gets drastically weakened by the excess heat and decides to part company with the turbo and go on a holiday out the exhaust"
also i think this pic belongs in this thread
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5253314
So can high flow cats still permit flames (200 cel or 100 cel)? Or does it fully have to be no cat (too loud)? Does it work with non turbo engines? Technically it should because it is unburnt fuel and exhaust heat, unless the turbo contributes to a lot more heat...
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5254595
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
