ok so i put my walbro pump in today fitted strait up to my stock set up pretty much... plug and all!!! :blink:
then i attempted to do this 13.8 volts thing... bassicly
got a relay... had 4 terminals... 2 input and 2 out put...
2 inputs were 12v (dirtect battery feed...) and a ground...
with the out put... i cut the positive and put the 2 ends on the pos and neg.... and grounded the negaitve to the body...
i managed to get 12.5 or there abouts... did i do this wrong? any one who has ACTUALY done it got an answer for me??
it did drive like this but then it cut out n went all shit... had to take it back to stock wiring in the carpark of the local pub lol...
https://www.sau.com.au/forums/topic/322427-fuel-pump-dramas-need-help/
well....you are checking voltage with the motor running right? 12vish is right for battery alone, alternator should show 13.5+
the wire you ran from the battery to the relay has 13.x at the relay end when the motor is running?
pins on the relay should be:
30 - wire to the battery (fuse near the battery)
85 - earth
86 - original fuel pump positive (signal)
87 - output to the fuel pump.
you should get the same voltage at pin 87 as the battery when the ignition is on.
have a look on the bottom of the relay, each of the pins will have a number stamped beside it. it should be the same number on all automotive relays, so hook up the wires to the pins Duncan said and it will work.
basically explained, pins 85 & 86 switch the relay which joins pin 30 to pin 87. so when the original setup tries to turn the pump on, you use the original positive feed to the pump and any ground to switch the relays coil, which connects the new 12v feed from the battery to the new fuel pump.
ahhh thanx so so much!! I'll get onto it!! ;)
going off those pics, if you hold the relay the same way as in the pic this should work,
it also doesn't look like an automotive relay, but should still do the same job, just make sure you insulate the terminals so they don't short out on anything. if you want a proper automotive relay go to supercheap, they aren't expensive to buy.
its like that 3rd pic
the 12v on the left is from the ecu
the 12v on the right is from the battery
the ground goes to the chassis (make sure its a good contact, i.e. no paint in the way)
darren yes i have read that... and thats when i originally did but it did not work :) ill try the ways mentioned and see what happened... then im unplugging the pump and getting the volt reading from there correct?
so i tryed this one and its getting power all the time now... do i stick with this and wire the battery lead into the acc.... or... have i stuffed it up once again...?
so ive played a little more... it only comes on with this set up when i turn the key... once its on pulling the fuse nere steering wheen doesnt stop it... and it doesnt no when to turn off?
Edited by chef_stagea
i went out and swapped my relay over.... got a proper automotive one... same problem.. turns on with ignition... runs at like 14.2 v then once you turn the key off... it turns the fuel pump off for a few seconds then keeps pumping and just flows threw the engin and back to the tank....and has to have the power cut from it momenteraly to stop it...
on my relay...
pin 30 is my new 12v lead from battery...
pin 85 is earthed
pin 87 goes to the fuel pump (positive)
and pin 86 is the car end of the old positive lead...??
i did read somewhere about r33s having the negative wire on the fuel pump (untouched at this stage) grounded? i cant see this doing anything?
the reasoning behind grounding the old pumps negative is because there is a capacitor rigged up in the old pump setup, its there to help with power surges and general smoother running of the stock pump. because you are using the original pumps feed to switch a very low current drawing part (relay) it could be taking a while to dissipate the capacitors charge, hence the relay is staying pulled in. ground out that negative and see if that solves your problem.
ps. that last diagram you posted is what you said you have done anyway :)
Edited by QWK32
ahh OK I may have been wrong about pin 86 and 85.
Check if you keep positive voltage at the old positive feed more than 10 seconds after the ignition is turned on. Same check for the original earth - does it have continuity to earth more than 10 seconds after the pump is turned on.
If the positive drops out, old positive to 86 and 85 to earth
If the negative drops out, old positive to 86 and old negative to 85.
That should do the trick either way - as Josh said it might be earth triggered
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
