Get a petrol jiggler hose, put the brass end in the tank (of course it will have to be quite long), jiggle it a bit and that will get most out
Then take the line off the fuel reg and turn the key to ON so the pump primes. Repeat. Will take a fair while but it's simple.
Btw that's what happened to my car when it switched to e85. I got the shits with the tiny bit that was coming out with every prime so it was easier to just turn the fuel pumps on through the ecu and it took hardly any time at all to empty the tank
Is there a way to turn on the pump from the powerfc hand controller to keep working til it runs out?
I had to empty mine and i used the jiggler through the boot opening. Was a pain and it stank of fuel everywhere but it got done. Then a mate said why don't you just drill a hole in it at its lowest point and then use a roofing screw ( which has a rubber seal on one end ) and put the screw in the hole. I thought that could work but didn't attempt it.
On my previous car I pulled off the fuel return line and pointed it into a bucket and started the car. It then pumps all the fuel into the bucket.
this is what i do when i swap between 98 and e85
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
