  • Replies 260
Yes shame more don`t come out,see S2 silver leave Craig parked next to then ,
& we watch as they drove away :/ ,
but we are in WA not many come to catchup these day`s :thumbsup:
i would have but panna is 1500kms away in the sunny pilbara just south of karratha
Thought id post this up to see if any of you guys were interested in this. Im organizing it through another group im part of. There will be a mixture of cars and bikes. More than welcome to come along.
Planning on cruising to Collie for lunch then cruise back.
Date 15th Aug
Meet Point: Armadale Macca's
Time: 9am
Depart 9:30am
Aiming to be in collie around 12pm
Will be back in perth around 5pm
Total distance is around 400km
Caltex 98 in Collie 175km
Bp Boddington 290km
Jnr
Date 15th Aug
Time: 9am
Depart 9:30am
Bp Boddington 290km
Jnr
I've got a tournament that day and doing a trip to Albany on Friday for a funeral :P
appealing, i saw your stagea on sundee....driving past trigg in a grey 180sx. i beeped. :P
be keen to bring the stagea out on the next one.
We spotted the grey 180sx, didn't know it was driven by a fellow stagea owner!
& we watch as they drove away :ermm: ,
but we are in WA not many come to catchup these day`s :)
Hi Chuckie , Spewin i missed this bin a bit slack on the forum. Cory.
Well we have SA visiter over Ruby & wife are in town for few day`s so maybe catchup one evening might be a BBQ lol,will see what he`s upto & sort something out SO those that may be about POSTUP if your interested & we can set time & place northan Sub`s ok Cheer`s Chuckie.
As Chuckie said, I'll be in WA from friday to monday. Staying at Hillarys area. I'll have a hire car and gps. Should be free most times except during the day on saturday and sunday. In town for a sporting event. Wouldn't mind catching up with fellow stag owners and seeing how the westies roll. :laugh:
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
