Whole list of parts for sale from my 1999 R34 N/A GT-four sedan.
Front seats $200 pair with rails
Rear seats $150
All seat belts $200
Parcel shelf with 4 tweeter holes cut out $50
Roof lining in black velour $150
All pillars in black velour $60
Fuel tank $250
Front bar $200
Front guards $ 200
Bonnet (couple of stone chips/pin dents $250
Bonnet latch $50
Bonnet hinges $50
Cusco Master cylinder stopper $80
Glove box $50
Kick panels $80
Door Trims $100
Cusco Full bolt in cage $1200
Brake master cylinder $120
R34 GT-four gear box, Small crunch 3-4. Chuck some redline in and she'll be right, Complete manual conversion $1200 Will include clutch master, pedal etc
Clutch pedal $120
Clutch master $80
Brake pedal $50
Accelerator pedal $50
R34 N/A brakes complete set, discs, calipers, lines $300
R34 N/A air box $50
All Air con stuff $200
Brake lines $50
Heater box (non leaking) $150
ABS module $150
Climate control display $150
Bnr34 brembo's low k's, slotted rotors, A1RM pads, braided lines, complete set $2800
R34 Rear hubs, handbrake set-up, handbrake lever, lca, $300
If your after a stock part that isnt there let me know.
Will be adding more as i think of it.
Cheers Luke
https://www.sau.com.au/forums/topic/322680-lots-of-r34-parts-4dr/
  • Replies 47
hay buddy
ill take the ac control unit for 150
and the a pillars retrimmed in velour if they fit a coupe ill also take them
also where did u get the carbon inserts for the dash and the doors?
and
where did u get ur dash flocked/retrimmed?
i also spoke to u a lil while ago about a greddy oil filter relocation kit sorry i didnt get back to u i bought one brand new
cheers
julz
Edited by GUN_METAL_GTR32
Wondernig if you are interested in selling your CF centre console garnishes. The gear stick + ashtray surround mainly. THey should fit in a 34gtr yeh?
Probably wont sell that just yet. Not sure if im gonna use it or not. If i do sell i'll let u know.
Also forsale BNR34 injectors $330
All Pm's sent to :yes:
Edited by Luke_ENR34
Man why you gotta do this now? Id so have that cage if i wasnt in the middle of doing a shit load of work on my house. Wanted a jap cage for my 34 for ages...
Could always make a offer :)
Will update with pics soon.
Also got:
R34 Steering wheel with airbag (manual) $200
Passenger Air bag (been retrimmed) $100
Random RB26 oil and oil lines $50
Random RB26 Bov's, piping $250
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
