10 psi!!!! Jesus.
For sure will be looking at new dumps in the future. But I wish to enjoy the new found power. Besides it keeps me interested in the car if there is always something to do. :)
Are you running mafless?
I'm running twin Z32s with stock airbox
Haha don't worry you will find plenty to do to the car if you really look ;)
  • 3 weeks later...
http://www.gtr.co.uk/forum/96210-5s-7s-7.html
Just read all 13 pages, not to much mention of the -9's though they seem to have a totally diffrent opinion on -5's.
Main jist here seems to be -7 or -9 with stock motor, -5's for a storked engine.
Yet they are claiming to be making boost by 2000RPM and on song by 4k. Non stroked motors.
a few posts from a couple boys here aswell
Also don't forget that thread is quite old for the most part (2008 etc). There won't be a lot of talk of -9s as they didn't come onto the market until ~2008/2009 IIRC as they were still under the HKS GT-SS banner and expensive, and then Garrett released them etc.
I mean claims in that thread that -5s are "really into it" by 3000rpm are just plain silly. That same user then posted a graph - 4000rpm not even 170rwkw ... lol... really if that's "into it", i'd be worried. :rolleyes:
Yes they might be building boost - but in 4th gear it'll still takes you longer from 3000rpm-4000rpm than it does from 4000rpm-8000rpm on a 2.6ltr, once the turbos are well into their sweet spot and the motor is working.
End of the day it comes down to ones 'definition' of what is/is not laggy. Turbos that come on @ 4000rpm-8000rpm for ~370rwkw or turbos that come on @ 3300rpm-7500rpm for ~330rwkw
Basically the same power band - just totally different delivery & RPM use. Then there is also response onto boost in/out of gears, on/off throttle etc.
End of the day - do what we've told you. Jump in the passenger seat and see for yourself and what you prefer.
  • 3 weeks later...
Ok, Sifted through the rb26 turbo upgrade thread,
Looked at all -5 and -9 setups with similar mods ect
-9/hks gtss
3k rpm= 130kw
5krmp= 254
100km/ph= 16kw
110km/pk= 130kw
-5/2530
3krpm= 85 kw
3krpm= 100kw
3390rpm=80kw
5400rpm= 200kw
100km/ph=100
100km/ph=110
110km/ph=140
Not many -9/gtss examples, Though
Taken a while to sift through it all, So i thought id post this up for reference to anyone else making the choice, These are all on a std 2.6 capacity
Was actually going to go against everyone's comments and get -5' this week. But this proves the -9s shit all over there bigger brothers, Unless you plan on doing ridicules speeds.
Dude, are you still trying to make up your mind?
man you just need to take the plunge and go and get whatever your goal is.
Is your goal 300-350kw? -9's
is your goal 350 - 400kw? -5's
Done, go spend your money
wish it was that easy....the KW range is not my goal. Although it easier to strive for a particular figure. Now im more looking at the driveablilty.
All fair and well to say you have 400kw....but its not very practical to have that at 150km
Main reason for me doing this is to compare the power at the lower range. And to me it looks like the smaller set up has alot more usable power. ( if ive read then all correctly)
ive taken the time to post my findings for people in the same position in the future...Dont see the big deal?
Nah thats not the problem. What is working on my nerves is, we have said countless times, if you want it power sooner ie boost sooner, then get -7's or -9's and they will yield 300 - 350kw!
If you dont car about lag and your car is not a daily and you want peak power then get -5's and once again, they will yield 400kw's.
I see no fine print in this, it looks very straight forward to me.
Nah thats not the problem. What is working on my nerves is, we have said countless times, if you want it power sooner ie boost sooner, then get -7's or -9's and they will yield 300 - 350kw!.
has anyone actually got 350kw from -7's or
9's
I think someone did 360rwkw, but it's never been repeated (or confirmed).
Common is 320-330rwkw realistically and what people should expect.
+1 to comments thus far. I'm kinda sick of getting PM's about the same topic & questions :unsure:
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
