Take care of michaels car :thumbsup:
good friend of mine
So bro, (op)
What happened to making the decision yesterday?
You have all the information in the world. All of us have elaborated so much in this thread, that you should know by now what you would much rather want.
Have the invoice on my work desk. Will be paying for a set of -9s first thing tomorrow morning
good friend of mine
Ahh thats the michael u mean. Bout to start swapping his turbo's over. Then injectors and a tune. Should make a little bit more than the 210kw he has at the moment
No Greddy dump/front pipe extension. Standard AFM maxing and I didn't want to push past it. I'm happy with what it makes and it pulls like a f**king train all the way to redline. Thinking of going Nismo AFM later and playing with the cam gears a bit more to make it more responsive, while making a bit more power.
Which is what I don't have. Need to sort out a big 4" high flow cat or something.
You should be into the 300s with 19psi
That would be choking your setup and a quick simple install and retune and car will feel
Even better
  • 1 month later...
Okay, bumping up this old thread!
-9's look like the best for the response.
However, if someone was to go -5's and threw in some Tomei Type R cams, would we still be talking about this huge lag?
I'm pretty new to this, but I would think a set of cams built for response could indeed reduce this lag? Maybe even Mine's cams hehe
You simply won't be able to to put cams in to combat the size of the turbos when talking about those two choices. Yes that big difference in lag will always be there although you may reduce it by a bit It's not going to go away completely and won't ever be equal between the two turbo choices
A set of -9's and low duration cams would be heaps for the street.
Larger cams will not magically give you 500rpm better response on the street or on/off throttle.
  • 2 months later...
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
