I have told my sons to bury me in my N1. It's a keeper
Fat chance that is going to happen, after you pass from this earth they will be sad, untill they realise the car is theirs :cool: it's evil but that's the way it is. You can't blame them.
  • Replies 52
Wow the car got passed in at $59k, guess you guys were wrong wern't you, import 22b's are worth even less than I even thought it was going to get at auction, I thought it would hit atleast $63 because of excited enthusiasts. I still don't think it's worth more than $40k + transfer, auction fee, rego, ect... so something around $50k all up is what it is worth maximum in todays climate in this country.
Can you show me where I can by anything other than an import 22B recently?
Also, what would IC's R34 N1 be worth in your opinion?
Iron Chef, is it a V-Spec or V-Spec II? And yes, pics please!
how about they come up when they come up and i'm still sticking with the mossman 22b as AUD because that's what the ad had on it so couple months ago. and no i didn't confirm in person if it was AUD or JDM.
I got no idea what an N1 is worth here, especially one like this one, there hasn't been enough of them sold here to know what it's worth, why don't you value it yourself, you don't need daddys hand to hold you do you? :cool:
They won't even be sad, ha. Well the eldest one did get the gts-t. The youngest can't drive a manual. lol
Pics of both N1's please
Therein lies my point, if someone was after a 22B then the options are limited to the 5 AUD ones and the PI ones. Ie seller's market. So one would have to pay the (seller's) price or wait a while to find one.
I'm not the one who is competing against the 'whole of SAU' on guessing car auction prices :sweat:
I assume you work for an auction or car valuation company or perhaps insurance, hence the question.
And I am not in the market for an R34 N1 :whoops: Just asking the 'expert' :cheers:
Mine's a V Spec II N1, interestingly enough, there are three of them (including mine) in Australia - the other two have been used in competition for Targa Tas and the like. As for V Spec N1s, I only know of kimbod's in Australia.
With the 22B, there were 5 imported from Japan by Subaru Australia for select customers/collectors, who then either got the poops on or one of them ponied up with the cash to get his road registered, so all five owners were the offered the option of doing so.
:banana:
I'm not the one who is competing against the 'whole of SAU' on guessing car auction prices :D
And I am not in the market for an R34 N1 ;) Just asking the 'expert' :rofl:
You can assume that but you are far from it, I don't work for anyone. I work for my self, the only way to work.
And it's not car auction prices, it's car valuation which you would think used car guys should know a thing or two about...
LOL and 'market value' is not actual value either. :P
if there was a market value established for a one off car which has never been on sale other than directly from holden.... i'd like to see it :P
So true about "Market Value" Right now I have an R32 V-SpecII with no turbos, and in need of a respray, market Value would be about $12000, Not sure if anyone would pay that for it. Fact is if anyone rocked up with $50k, it would not be for sale, because it's value to me is higher than that. (So just imagine what it would be worth to me with turbos...)
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
