Just to stick in my two cents on cages. Normally the wording you see is that cages if fitted must comply with CAMS specifications. The only way to say that a cage was CAMS "Approved" would be to have the car log booked for competition with the cage in it.
Essentially most cars in most events are not required to have a cage but if you have a cage fitted it should comply with CAMS specs (Which pretty well mirror FIA specs) regardless of if your car must have one for the event you are doing or not.
Saves a few of the beauties I have seen, like a Torana with a cut down trampoline frame inside it. I am not kidding! Another I have seen has the main hoop in front of the drivers head!
  • Replies 146
Posted Images
well if thats what people are doing then its a good thing they enforce it..
i was thinking of the older bolt in alloy cages when i mentioned non approved cages...
thinking that having one of those has gotta be better than nothing at all
but blue's post has shown that theres good reason for the rule..
You would probably have trouble with an alloy cage as they are simply not allowed any more. Basically the only cars allowed to run them are cars that were log booked with the alloy one in them and you would have to be able to produce the log book to prove it. I think it was in the late 90's when they banned them.
OK, I have my CAMS! Confirmed my event entry!
Did a full service & run through on the car!
Got my helmet, fire extinguisher, bonnet latch, etc!
READY TO ROCK!
Very excited!
Slight concern with oil pressure but putting it down to false reading from factory guage.
So there's 57 confirmed entrants so far.
10 skylines, 12 BMW's, 8 EVO's, 1 commodore, 1 Lambo, 1 911 and of course a heap of Subbi's!
Sounds like fun to me.
Can't wait to actually meet some of you forum people too!
yes coming along to laugh at the rest of us is encouraged.
just turn up to sandown through the dandy rd entrance. security on gate will ask you who
is running the day, maybe.
park out the back of the pits, with all the other cars.
you can stand up the top of the pits or wonder through.
im also pulling out. thats 2 that ill have missed, and round 5 ill be overseas.. bummer.
might come down say hello.
how come u pulling out chris..??
i'll be there. at this stage it looks like its gonna be a long day on saturday getting alignment/tyres/sorting the car out.
does anybody know of a rb25 pfc i can borrow for a few days by any chance .??
i know this has been discussed, but im a little confused, should i leave my full safety 21 cage in or pull it out before i go.??
dont really wanna have to pull it out at the track on the day after getting knocked back.
Brad
You'd have to look at the cams manual to be sure.
Prob will be fine though coz I know that there are other guys running jap bolt ins.
brad the car just wont be ready. i got the turbos and all that back together but now i got an epic miss under boost, idles and drives great but as soon as we get around .7/.8 bar it all turns to shit. i've gapped the plugs down to 0.65-0.7 but now i got the zorst off again cos i need to chop out half the useless bracing underneath to fit jacks exhaust... bottom line is its best it goes on the dyno before i abuse it for a day and they're just flat chat this week.
just playin it safe.
some crappy s14 i think.. hahaha j/k
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
