  • Replies 51
Posted Images
Hi all,
I've just got my car back after some major modifications with a healthy 272.9rwkw before 6000 rpm - obviously my crappy 235s have no chance of holding it in 1st or 2nd (barely in 3rd) so I can't get most of my power down.
The search is on for some new rears - to match the fronts i need to go 265/30/19
I was thinking of the Nitto NT05s but they don't come to Aus in this size apparently...
The two others i'm tossing up between are the Pirrelli P Zero Rosso and the Yokohama Advan AD08 - prices for these are around the $600 - $650 mark each (ouch :blink: )
Anyone have any thoughts?
Cheers.
Smokohama's....
KU36, 290rwkw, 560nm torque i believe. Great tyre :domokun: - i've got a lot of suspension work though.
Daniel (and others with them),
How do the KU36's go in the wet with that power? Also what size rim/tyre combo are you running? If it grips really well mind putting up your suspension settings up too, mainly camber etc?
I have seen the KU36 & KU31 tyres mentioned a bit lately. I thought that the KU31 might be a little bit better in the wet, only because it is not a semi-slick type design. Wear of KU36 will no doubt be a slight downfall for them.
Cheers,
Phil
Hey for what it's worth, Today I fitted 255-35 18's on my 270kw RB30 R34GTT. as long as I don't side step or flat change I can't light the tires like I could with my 235-40 18 Hankook k104's by simply rolling the power on in 2nd and 3rd gear (which cost me twice as much)
Yes it was a GTR, but was running RWD
It's all in the suspension settup
oh please share this "suspension settup' because Ive found nangkangs are a really crappy tyre for grip...
if its just down to suspension then I want to know please...
Yes if you guys that claim you can't get your xxx half decent tyre to let go on WOT could post your suspension setups that would be great! :thumbsup:
My average 235s won't hold past half throttle in 1st or 2nd in the dry with standard suspension and slightly lower springs woth 273rwkw.
Some traction issues will no doubt come from how the power is delivered. if you have a fairly even rise in torque then you won't spin them as much as there's no instantaneous jumps in boost. Mine hold on ok but with a smallish turbo it comes on fairly quickly. Someone who has a large turbo on that does nothing and then all of a sudden goes from nothing to all in the blink of an eye I'd have thought would struggle with traction? I suppose though if the suspension is set up well then maybe it's not an issue.
Well for example my R34 has the sK group buy setup ie Bilsteins, white line springs, whiteline swaybars front/rear, pineapples, rear camber/toe arms, front castor arms, front camber bush's.
I think people run way too much camber, too low, too hard. I'm really impressed with these KU31's, they were damn cheap and have blown the K104's away in sheer grip with my car any way. since fitting the KU31's I cant spin the tires by simply rolling on the throttle any more. I used to be able to do it 1st 2nd even 3rd on some rd's.
I've had K104's too and was quite disappointed in their performance after reading so many positive comments about them.
I got my Yokohama Advan Neova AD08 255/30/19s fitted to the rear yesterday.
I must say that first impressions - these are some mighty impressive tyres!
They ALMOST hold full throttle in first, letting go around when it hits peak power, 273rwkw at 5.5k rpm (ish) if I have my foot mashed. 2nd I can hold it to the floor til redline - and the shove in the back and acceleration tell me my old tyres were probably getting no more than low 220kw to the ground at best!
Even in the wet this morning they held really well and feel very very stable. But I guess they aren't cheap...! :wacko:
This is with stock suspension and lowered king springs - no camber adjustments. I'm going to get some +ve camber dialled in to try to get it to as close to zero as possible under squat and hopefully 1st will then hold...
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
