Cube wheel options
60 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 114
what are these 15" and 16" things you talk of? How do you spell that? "W... E... A... K"?
18+ or GTFO. Your car is gonna stand out like a midget in purple pantaloons, do yourself a favour and make sure your wheels are just as outrageous.
lol It was the Sportmaxx 501s that I originally ordered (16x8 +15s...), but after waiting 2 months and being told I needed to wait another 6 weeks by the Aussie "supplier" apparently due to a second stuff up in the order from the warehouse in the US, I told him he could stick it and give me my money back. Feel free to PM me for the name of the company.
The problem I had with going too small is the massive radius of the guard lip, it tends to make smaller wheels look like shopping trolley wheels, regardless of how wide they are. The only solution with smaller diameters is to dump it stupidly low, which then makes it too impractical for every day use.
I ended up buying the white Meisters, which despite being 7" width (bear in mind the factory alloy is 5.5", the steelies are 5") should be cherry ripe for the offset. Now to hunt down a factory strip kit in white to match...
UGLY?
I really think you need to have another look,. modular one piece forged wheels extremely lightweight as used on some rather tasty European cars. Here is an example of an Audi R8 and a R35 GTR.
Edited by Adelaideprosound
Actually, while I have your attention for a moment, have you ever seen leather (MSpec) R34GTR seats come up at the auctions? Do you know a rough price I would be looking at?
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
