All the internally gated turbos I have seen/used have some adjustment in the length of the actuator rod.
Cool cool.
I assume this is not the sort of thing I should just play with and 'see how it goes' but rather stick it on the dyno?
what do you want to achieve ?
Just to see if it helps bring the boost on a little faster - looks a little lazy coming on... The other side of it is playing with boost controller gain etc.
If it's something I could do myself without a big $$ outlay on dyno time (as i've just forked out a crapload to get here!) then i might play with it. If it's a bad idea to do it by the seat of my pants dyno / boost gauge then i'll wait till i do something else on the dyno...
adjust little bits at a time, take it for a drive.. but ur going to need to turn ur settings down on the boost controller, as making it tighter/harder to open is going to want to raise the boost level.. so turn gain down etc
Turn boost controller off take it for a run not when you hit max boost.
Adjust arm length a tiny bit and go for another run and not when max boost it ( boost will likely increase as well)
Keep doing that until you get no more gain but be careful your not over boosting.
When you have found the sweet stop user boost controller to hit desired boost.
Are you using the actuator that came with the turbo?
They arent the greatest, quite soft and creep open a bit, that's probably causing the slow boost.
I got one for a mate for his 3076 from USA, 14psi spring. The overall size was larger, and it was tight as buggery compared to the "stock" actuator. (when doing the old "pull on this" trick) :blink:
PM "Lithium" and ask him a question or two. Hes tried a few different approaches to the spool issues.
Edited by gotRICE?
Boost controller is a Greddy profec II spec B (or whatever it's called).
I 'asked' the place that built my car to get the larger actuator on the 3076 as apparently it comes standard from Garrett... I can't seem to move the rod at all by hand...? (and i'm not a small dude)
There is a thread on the rod, so could turn off the boost controller as suggested and see what tightening or loosening it does...?
to add more preload to the gate wind the road so that the overall length is shorter. only do it a few mm at a time tho. once you have enough preload to keep the gate shut properly use the profec to bring it on earlier by slowly increasing the gain and start/set boost until it spikes then back it off a touch. if you want 18psi i'd start with a set boost of 14-15psi and wind the gain up.
this will change the torque around that area. ideally you should get the tune checked around that area but if you dont want to do that just keep a close eye on your knock levels (if possible) whilst adjusting the boost.
Well here's an advertisement for not always taking dyno readings as gospel - I did some testing on the road on the way to work this morning - it's kind of hard to tell exactly since i can't use WOT in 2nd as the back goes by 4500rpm or so but i was making over 1bar by 4000rpm and was definitely at the full 18psi well before 4.5k. At which point i was going sideways down the road and had to back off... :blush:
I assume the tuner didn't plant his foot on the dyno from down low and this is why it looks lazy onto boost on the chart...?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
