  • Replies 51
Damn... I only just saw this. It's really good to see car clubs do things like this, shows that we are not just reckless hoons out to create terror. If there are any spare spots left me and my brother will try get there too :D
Awesome, ok roll is as follows:
5.05 - twins +1
5.45 - HEKT1K
6.05 - Adzmax
6.15 - Basti
6.45 - Trent (Motorbikes)
6.45 - Ant (Motorbikes)
7.00 - Me +1
Let me know if I've left you off!
And a couple more to confirm. Since this is going to span out over a couple of hours, we can organise on the night for a group to head to food if it gets too boring :D
phew. i just shat myself because i thought this was today. all is well. i have another day in which to potentially forget tho so hmmm
Yeah you forgot to goto the SAU General Meeting tonight :bunny:
You ppl gonna remember to goto Garage Cafe tomorrow night at 8pm? :P
Hey all, sorry for the late notice but I've got a pretty bad stomach bug. I'm off work today and wont be able to come down. I'll give them a call now to cancel my spot. I'll pop down to the local bloodbank when I'm feeling 100% Hope all go's well :D
All good! I head every two weeks so if you want to join let me know :P
Have messaged most of you my number, will see you all there and have booked a table at the cafe :D
See you at Garage Cafe at 8pm!
Sorry I didn't wait up to say hello guys. I had finished at 5:30 and waited for an hour or so and didn't see anyone :thumbsup:
I'll try come out to the next apple peel/garage cafe meet and introduce myself
Guest
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
