Couldnt find the noob section here
(dont think it exists)
ive just got a r33 gtst (first turbo)
cars pretty stock cept the exhaust
and ive been told not to start the car immediately and drive
and i should let it warm up
in many instances im short for time and cant start it up and wait 5 mins
is this going to be a big problem
btw i do not boost while the engine is cold
dont give much throttle and change gears around 2.5krpm
https://www.sau.com.au/forums/topic/323929-noob-question/
1. congrats
2. letting a car idle for ages is bad for it, it's a lot longer runtime for the engine when it's not in an optimum state (cold)
3. start car, let it idle for ~20 seconds to let the oil circulate and then drive off gently. I stay under 3.5k if possible and no boost until it's warm.
whoever told you to start your car and idle it for 5 minutes deserves a stiff backhander. you're not doing the car ANY favours.
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5279457
+1 to above post some of the most important factors are having a car reach optimal running temp as quickly as possible.... too cold.. fuel is like sludge too hot and u overheat.... these days its fair cold so ye start the car 20seconds is perfect enough to then drive try get ur car to warm temp asap!
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5279466
+1 for what has been said above. people seem to think that skylines (and most imports for that matter) are some magical monster race engines that should be treated differently to any other engine, when in fact they aren't. you will find that in japan the original owners would've hopped straight in and driven off on much colder mornings than we get here.
just keep it off boost until the temp needle has reached half way and has been there for a minute or 2.
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5280350
Not even necessary to wait 20 seconds. The oil will be circulating within a few revolutions of the engine actually starting (don't forget you've been pumping oil while cranking to start).
Simply start engine, into gear and away you go. Every second that you delay is wasting fuel, and the excess fuel delivered while the engine is cold is risking dilution / thinning of the oil.
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5281616
an extra 20 sec isn't going to waste that much fuel, and it makes sure that oil has gotten through out the whole engine.
not sure about you but my engine starts pretty quickly, there is no way the oil has gone through the whole engine in the 2 or 3 seconds it takes to start. remember also that the cold oil moves a lot slower so it wouldn't run through engine and more importantly the turbo and be lubricating as it should that quickly.
if you have ever had an oil temp gauge in your car you would realise that your oil doesn't heat up much until after your water has come to operating temp.
i typically start car then go check my letterbox then hope inside and drive off.
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5283477
the hop in and drive off thing also comes down to where you keep your car, etc. if you park it in a garage and you have to reverse down the driveway, wait for cars, and then go then you really could just hop in, start the car, once it is running just start going, because the first 20 seconds or so of the car running you pretty much aren't doing anything more than just idling the car. if you park out on the street and can literally hop in and drive off straight away then it is a different matter.
at my place i will hop in, start the car, let it run for a second and then select reverse. all i have to do is let the clutch out enough to just grab a bit and the car will start rolling down the yard, then i just need to let it out a little bit to clear the gutter. then i can just turn the steering wheel and start rolling fowards down the street. i'll just put it straight into second gear, let the clutch out at about 10kmh and just stay idling along in second until the end of the street (about 4 houses away).
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5283549
I usually let the car sit for a minute or 2 just to let the fluids cycle through and then drive off and keep off boost for about 5 - 10 mins before boosting.
Once the car has reached normal operating temperatures, you are all good to go.
Before switching the car off, just drive off boost for a few mins and/or let the car sit and idle for a few mins and you'd be fine.
If you have been hammering it, give it more 'cool down' time.
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5283690
yes sort of. the best thing to do with any car though is to simply drive sensible for the last km or so before you get to where you are going. the car will cool down better when it is actually moving than it will just sitting there running. this way also your brakes, etc will also cool down a bit and not have super hot pads sitting against a rotor in the one spot as this can cause warping, etc.
if you drive the last minute or so of driving normally then you can just turn the car off and walk away when you get there. this includes turbo cars.
https://www.sau.com.au/forums/topic/323929-noob-question/#findComment-5285269
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
