Im in..
Terry what are the alternative payment methods ?
Hiya Ben, I've PM'd about cheque payment if you don't have VISA or Mastercard (Credit/Debit)
Most happy to do that - Humbla is sending a cheque too.
  • Replies 311
Posted Images
Tickets (with receipts) have now been sent to these postcodes (latest > first)...
2795, 2166, 2095, 5013, 2138, 2232, 2148. :)
It's been fascinating to watch so far, that every person has purchased 'multiples' of cinema tickets eg. 6, 4 or 2.
Needless to say, there will be lots of 'single' purchases along this 'journey'.
The Helpers/Organisers for this "Godzilla Event" are...
Nick aka Black_Widow
Matt aka God_speed
Shehan aka lankanboiiR34
Shanil aka SHANE666
Bobby aka NISMO
Eric aka Pezhead
Sam aka Rocklee
myself
+ Kat aka GTRKat (with the ACT contingent)
Without the above and SAU, nothing & I mean nothing, would get done.
The efficiency of how most of us got the 10th ANNIV of the R34 GT-R in April last year up 'n running within 6 weeks was remarkable!
And nothing on the 10/10/10 will happen unless Attendees like yourselves make this Event a sellout!
So, don't just come to the cruise; buy your tickets NOW @ $15 each (as per Payment options in the 1st Post)
Sorry if I'm just dumb Terry, just making sure, send $30 for two people? :( Very keen to come to this. Big trek, but worth it.
Not dumb! Just $15 for each bum! :blink:
So yes Owen, $30 on Visa or M/C with name + card# + expiry# + phone# + address; to send you the receipt & 2 tickets for entry to cinema.
Above details are to be e-mailed to [email protected]
'Twas good to see you again at the AGM! :P
Yep ill be in for this with the missus........this will be my first SAU cruise. +2
Yes Simon, just send those details of yours please to [email protected]
Enclose Name + VISA or M/C debit/credit card# + expiry# + address + Phone#
...if you will. Cinema Tickets and receipt will be out to you within a couple of days.
This is a great day for the girls too! :blink:
OK David lol
FYI, the aggregate of Postcodes (in reverse order - ie. last > first) where "purchased cinema tickets" and "receipts" have been mailed are...
4210, 2615, 2203, 2795, 2166, 2095, 5013, 2138, 2232, 2148. :P
Not dumb! Just $15 for each bum! :P
'Twas good to see you again at the AGM! :D
Awesome, will do that next Wed/Thur, gotta wait for payday! So if it's filling up fast, I'm screwed :down:
Was good to see everyone at the AGM! :D
Had a look on Google maps, it works out to be around 113km.. But I could be wrong
That's right mate, there's a GoogleMaps link underneath the map in the first post which gives turn-by-turn directions and says the cruise part is 112km, from the start point at Penrith, to The Edge at Katoomba. The distance from Katoomba back home also needs to be considered. But we've already got people coming from interstate, so the distance shouldn't be a barrier!
This is definitely something to look forward to, and we're expecting a great turnout. :D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
