I have some interior parts from a 32 GTR conditions noted. and photos posted
Interior side trims from the Rear passenger section (arm rests etc), $200 for the pair, VGC
I have the tops from the rear section too, not so good condition, $70 for the pair (furthest part on parcel tray clips are broken & some lifting of the vinyl)
Drivers and passenger A pillar trim, $60 for both
Center console with handbrake boot, in good condition $150
stereo surround also in good condition small hole in shifter boot $60
stereo and ac unit with associated mounting brackets $150
Glove box, also in good condition $100
Rear lights from a white 32 for $80 pair
Side mirrors also in white, fair condition needs painting or polish $100 pair
drivers and passenger outer chrome trim, $50 each
Rear r32 bar 50 bucks! in white. fair condition. could suit polish or respray
Sydney location can post/courier/negotiate into price.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
