I would buy......
95 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Well basically it looks as if I'm being rat-f**ked into the getting the TTS *awaits tidle wave of laughter* yes you guessed it, it has come down to "what car looks better" to the Mrs.
Currently she says
BMW E46 M3 "Looks dated, interior sucks"
BMW E92 335i "Likes a lot, but looks like an old mans car from the back"
Audi B7 RS4 "Old mans car, has four doors, wtf are you thinking"
Audi 8J TTS "Fantastic LOOKING car, wow I love these (even though your face is screwed up when you mention lack of performance"
Porsche 996 Carrera "I like them, not fussed either way"
I even threw the SLK 350 AMG into the mix today as we parked next to one......she said "What the hell is that, it's tiny"
I've tried saying we can get her a nice cheaper TT that's not Quattro (to apease the 'looks' issue) and me getting something more on the awesome side...but it's being vetoed hard at the moment.
I've suggested we just do the rounds of the showrooms and go for some test drives and see what we can agree on.
She's not a massive fan of my car that's for sure, I got an ear bashing today because of it's noticeable performance increase since she got in it last week, bloody human dyno I tell ya!!!!
Show her Post #72? So is your loved-one trying to justify her admiration of the TTS looks? LOL
  • Replies 85
Thought of a Japanese car that may be OK, she doesn't actually have an aversion to the 350Z, I'll test the water there again....she does however have an aversion to me turbocharging cars after the R34 "gave her a headache" funny as I don't recall her helping me do that or go through any of the R&D of getting it working, or even getting her hands dirty??????
But if she dislikes the m3 interior what would she think about the jap cars interiors? I'm very unimpressed with the r34's interior although i guess the 350z would have a better interior it is the flagship model
This is the particular "Fail" with the E46, it looks VERY dated, plus the seats aren't that flash a design either
The 370Z is also not to her liking, the 'tick' shaped lights and the fact it looks a little over the top with the styling also lost her, interior is fine though hahaha.
it'll look better than the 350 in a few years tho.... the 350 already looks dated next to the 370 :)
compare it side by side with the TTs and see what she says... servicing etc will be heaps cheaper, and remind her about audi's terrible depreciation reputation
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
