Hi guys well i got my tune done and im very very very very impressed! This turbo pulls so hard im always stuck to my bloody seat, I got what i wanted, i wanted 251kws at 18psi that was my goal for drifting at the track. This turbo is capable of doing 280kws, Toa from hypegear has the same mods as me with this turbo and he got 300kws+, but i didnt want that! my mods are the usual... Power FC,FMIC,Pod,Stock BOV,splirtfires coils,etc... Thanks to Tao from hypegears and Trent for tunning my car!!
here are some graphs.
Uploaded with ImageShack.us
its and adjustable actuator 1.4bar one i think, but my greddy profec spec b-II is connected to it... its not doing much.. lol.
With this highflow, it can do 280+ .... .63 raear housing.
Good result there should have some fun now, and yes you will get sick of it and want more ahaha im on 270 for a couple of weeks and am bored now.
300+ from a highflow? with what housings?
good result, looks a little late onto boost tho, what b/c you using?
Its not late onto boost thats just how it is because its a 3576 hi flow, its about right from the estimation Stao gave before on when it hits full boost.
Agreed, even with a .63 it should be earlier. GT30's with .82's are on about that (and make 280rwkw/17-18psi)
Not sure how it's going to crack 300rwkw if its 18psi/250rwkw... It's clearly showing a fair bit of restriction.
Good result either way, just need to ensure you keep the RPM's up a bit higher.
Keep that motor serviced well and a sane rev limits :whistling:
Keep that motor serviced well and a sane rev limits :thumbsup:
heheh thanks, its always serviced by me with all the good stuff :whistling:
ahhh sweet thanks for your graphs, i got the same turbo but in .82 and on a RB30. you have just inspired me to finally pull my finger out and put my cam gears on and fix the timing issues because yours is coming on a fair bit earlier even with the RB25. But damn the bang for buck you get with these turbo's is friggen awsome. did you use a VBAND setup also?? I think 1 suggestion for stao would be for them to use a 3" VBAND instead of the 2.5".
Chris
id be playing with your boost control man, my cheapy kkr430 /dsr430 makes 14psi @ 3500rpm , actuator setup to open @ 9psi, gain @ 50%, alot of preload on the internal wastegate.
different turbo, this high flow has a very open rear wheel so the 0.63 does'nt choke it. There is no more respone to be had with a controller or preload... we tried. This turbo with around 20psi will crack the 280-295 rkw no issues.
That should be obvious just looking at the boost graph, any more preload and it will spike too much.
ah sorry mate I just re read that yours has been put into a highflow. Thats awsome, mine is a complete new turbo that Stao made up for me. V band is like a pipe clamp flange on the exhasut housing, instead of using a 6 bolt flange like nissan use on the turbo.
regards
    • My son saw this Porsche 904 in Yodoyabashi in Osaka, not sure if it's the plastic or fibreglass version 767605763.559358.mp4
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
