  • Replies 41
Popular Days
i cant comment on the car tyres made by hankook, how ever in the transport company i work for, we now run hankook super singles on the frount axel of the trucks. they are by far the only tyre worth using, anything else doesnt wear anywhere near as good. the sidewalls are heaps stiffer than the other tyres we have used, makes them hard to fit but wear great. if i could find some hankooks for my car i would definately try them.
