Ive had no issues without running a BOV and i know of a few other GTR owners running to4z without a BOV aswell and they arent havent any issues.
Id be looking at your oil supply line and also remove and inspect the restrictor inside the turbo for any carbon build up as that will limit oil flow into the turbo and cause the bearing to wear out.
Ive inspected the turbo today actually and it feels like new still :)
ok just to put it into perspective. I had checked the oil line prior to removing the bov becuase I had to fit some flame guard for the line and everything was fine. I had only driven the car at pwercruise 31 a month ago and then twice after. This is when I inspected the turbo and found play. Id hate to see this happen to you just after fitting a new turbo. I do know plenty of people out there run no bov and havent had an issue, its just known that some people come into problems with the garret gt35r series turbo's. Anyway gives me a good chance to upgrade to a billet z :)
Shit I totally forgot to reply to your post mate. I think the main issue with gt35s on rb25/26s is the compressor surge you get at lowish rpm while under abit of load, ie corning out of a bend or uphill. I never get the issue on the street as its either full throttle or baby the car.
On the track i noticed that whilst trying to control the throttle in 2nd gear around a particular uphill bend, the turbo was building more boost than it usually does at that rpm and i was hearing abit of compressor surge. Im thinking its pushing out more air than the engine wants to digest with the throttles half way closed. I believe this WILL result in premature failure of the turbo so before the car goes back out on track again ill have some anti surge slots drilled in :) As soon as i herd this noise I controlled the throttle in a way that it would stop occuring but this meant that my cornering speed had dropped also which i dont care about atm, it was only powercruise :)
As for the damage due to the absense of a BOV when the throttle is 100% closed, im not a believer. Sorry :P
Anywho..
I installed my oil pressure and oil temp sensors today, getting 6bar of oil pressure on a cold start 1100rpm. During hot idle im getting 2.2bar. When cruising at 2500rpm im getting 5bar so pretty happy with those readings :)
While i was there installing the sensors i decided to remove my oil filter relocation mount to clean it, while i was tightening up the fittings into the housing itself the housing snapped :( :( FML - waiting on a new one to come from over east, lesson learnt! The old saying, dont touch it if it aint broke came to mind instantly haha
Also got around to wrapping the loom near my strut tower in some high temp shielding as it looked like a major operation (not really im just lazy) . Ill have some pics up 2moro!
Also thinking of installing a greddy radiator breather thingy i got lying around to get rid of the air bubbles while the car is running that the bleed screw fails to get rid of (or so they claim it does).
Heres a link to what im talking about:
http://www.greddy.co...d/rad-breather/
Just not sure where to plumb all the lines besides the obvious bleed screw near the FPR, somewhere in the rad hose and maybe even the coolant overflow tank?
Anyone fitted one before to an rb26? Some tips would be nice!
i just found this diagram that seems to make sense so might follow it
Edited by snozzle
Another update i should have posted a few days ago:
After many issues trying to get one, the universe has finally said OK, you can now have a washer bottle/catch can unit.....
Picked it up second hand off a forum member, the design of it is really good, has baffles inside the catch can side but i wasnt happy with the welds so i grinded them back to straight edges and painted the whole thing wrinkle black!
Just gotta buy a little airfilter to go onto the side and shes done.
Also now sporting a blue Tomei sticker on my timing cover for cooler engine temps and extra detonation protection!!
Yes it is that simple and yes they really do work well. The only thing I would suggest is that you be careful to not over-tighten the 6x1mm fitting that goes into the head as it is extremely fragile due to the hole drilled through it, and also because its chrome plated mild steel. Could have been my enthuesasm but mine broke so I made another out of a grade 12 bolt.
One other thing I would suggest is to seal the radiator shroud onto your radiator so the fan can only pull air through the radiator, and then seal the radiator to the front of the car by replacing all the foam rubber you are missing around the radiator. An air leak around the radiator either drops the effectiveness of your fan by allowing it to draw air around the radiator, or it allows it to recirculate hot air when stationary. Both are bad. Consider an air leak to be as bad as a coolant leak.
Even if your engine isnt over heating, hotter average coolant temps in the radiator temps mean your clutch fan will be engaging and working harder and directly robbing more power and throttle response at all engine speeds.
The greddy tank, and radiator foam allow my engine to sit on a stable nismo thermostat regulated 68 degrees in 32-35 degree heat like we are getting during the day at the moment.
Thanks for your input mate, much appreciated! Ill work on all the things you have mentioned over the next few weeks as they do make alot of sense :)
Im not getting any overheating issues, never have, but cooler is always better!
  • 1 month later...
  • 4 months later...
Long time no updates!
Car has been running sweet for the past 6-7 months, however, my time with the car has now come to an end as it is now sold. It's getting picked up on Friday. :(
The only good news i have is that the car is going to be featured in Perth street car magazine so keep an eye out for that :)
Some pics from the photoshoot;
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
