Gav's car with similar spec to yours pumped out around 560 at the very least. Then he added e85 conversion.. so a theoretical guess would be around the 600+ mark.
I think you should get a 14mm rail conversion and some 14mm injectors for less price than the hks ones, plus you can then go e85 later for that extra ~10% in power increase just from a retune.. Cheapest investment/performance ratio for sure..
I am not looking to smashing numbers with this engine.
I want it to last for 5-6 years, without having to worry about it.
500 -525 at the wheels will be more than enough.
Plus I bought Gav's old injectors hahhaha
hasn't he done some really hard km's on his motor since it was built, 3+ years ago? If its tuned well, surely it'd last if the engine is built properly.
E85 should increase torque over the entire range, sounds fun indeed for track.
May as well go hard and enjoy it haha
Edited by s2d4
I'm also in the middle of doing a 2.8L also although I used Pauter rods same as Gav and my crank came from the UK.
So who are you using for your engine builder and machinist?
R
Ant at X-Speed is building the motor.
Machinist is via LF, Ant's recommendation
Who's LF?
Ants going to build it, that will deff be a machine. With Ant doing it must around 30K+ easy.
Hope to see more pics. Are you doing any modifications to the STD gearbox, brakes, clutch etc?
What compression are you going for?
Turbo configuration? Have you decided on a cam duration and lift yet?
R
Hey Mike,
Yes the 2.8L bug finally got you too. Good choice in acquiring the HKS Step 2 kit, combined with -5s should make for some real fun!
Hmm... E85? I wonder what Racepace can do with E85 tune in my car.... Instant 105 increase in power across the whole rev range with proper tune and same hardware, sound too good to be true.... need to do more research.
Cheers
Matt
Who's LF?
R
Probably LF Performance.
No matter who builds the engine it's going to cost and Ant is the man in Perth when it comes to these engines. Do it once and do it properly!!
Rob have you still not built your thing yet?? I remember talking to you back in 2007 and though you were pretty close then.
He is using -5's.
Hey John,
Few things in between have got in the way of my build. Also My car is getting a bare metal respray as well, so its taken a while to get all the rubbers together etc etc etc
Even getting R34 GTR dump pipes have proven to be near on impossible. So at the moment trying to coordinate rebuild on motor and shell respray.
Anyways I will subscribe to this build to see how it progress's.
Rob
He is using -5's.
Pity you weren't paying attention to the for sales forum a few weeks back, I had a spare set.
Hey John,
Rob
  • 3 weeks later...
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
