Hi all! I think i will go down the CDI route. Autronic sm4 with Cdi 500r to be exact. And i was wondering what would be the prettiest way to mount them in a BNR32? i would still like to use the RB26 coil pack cover to have a more stealthy and cleaner look. Is this still possible? I have purchased some LS1 coils which i got cheaply. Is there some way i could mount these (in a cradle etc) and still have it aesthetically pleasing? Where can i get a cradle for the coils? where should the cradle be mounted? is there a way around this? I guess the coil pack cover isnt essential, but id just like to keep it if i can. If anyone has pics of their setups, could you please share them with me?
cheers
chris
https://www.sau.com.au/forums/topic/327084-ignition-coils-for-cdi/
ls1 coils will explode. they have interal igniters.
i have spent ages trying to find a propper "cdi" spec coil for my autronic. i have been using s4 13b 2 post coils. the 1ggze 2 post ones are good to, aswell as gto tt cols.
i dont like the idea of running 2 coils in parallel for waste spark. each coil will be getting halve the energy. but it has been made to work well with the factory 26 coils.
for cdi you want the lowest inductance coil you can find. higher inductance makes good spark in normal transistor ignition, but for cdi they take to long to saturate. they work but not ideal.
motobike coils are the gun thing but ive yet to test any.
in your case id just use the factory coils wired in parallel.
having said all that, i can get a 3" spark from my mazda/denso 13b coils. but they are really big.
Mercury marine coils are the go for a CDI system (the same coil used on a 2.5 2 stroke mercury outboard). Have used them on another car that i have built with good success. These are the coils recomended by MoTec for their CDI8 ignition system. Will have to enquire about costing for you. I will be able to make a nice neat mount for you in keeping with the quality of the rest of the build. But if anyone has picks of their mouning set up would still be interesting to see how other people would approach it.
The ls2/yukon coils would have been a better choice. Check for on google I guess, these are a couple I found.
http://forums.nicoclub.com/another-success...ap-t435099.html
http://forums.nicoclub.com/ls2-truck-coil-swap-t478565.html
http://forums.nicoclub.com/my-ls2-ls7-coil-swap-t353832.html
A few references on how you could set them up. :)
they have inbuilt ignitors and will go pop/bang with CDI.
Yeah no sh$%, that was in reference to his ls1 coils and how he could mount them. He pbly could have just used the ls2/yukon truck coils without going cdi as it's 3 times more powerful according to data all over the net.
Edited by s2d4
the heat treatment's car gtr ran the mercury's with a boot ontop of the plugs and a rod through the hole in the coil's
i paid around $70 each for mine
http://i112.photobucket.com/albums/n179/ma...JUNE022_000.jpg
Edited by Walk510
I use Splitfire with the CBI500R and still had no problem (misfire or start up) with E85 and 2bars of boost.
How much boost are you planning to run mate?
The more you deviate from a stock setup the harder it will be to diagnose problem when it arise.
My Splitfires are 7 years old now, so I need to buy coil packs either way. I'm also going to run vipec xps- cdi unit. If I'm buying coil packs anyway, I might as well get coil packs designed for cdi...
I'm planning to run 25psi and upto 250hp worth of nitrous, so I need a gooood ignition system.
cheers
J.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
