What kind of problems would i have with regency if i this http://www.skylinesaustralia.com/forums/R3...56#entry5337356
Performance Features....
- Splitfire coil packs - no problems
- 550cc injectors - out for Regency
- 550 hp ATR-43 turbo - out for Regency
- Z32 Air flow meter - off
- Stealth return flow front mount intercooler - fine as long as no chassis is modified, holes are cut properly and mounting is secure
- Greddy turbo timer - take it out for regency
- Nistune ECU - not sure, but probably remove
- Trust turbo back exhaust - as long as its quiet enough
- Extreme heavy duty street button clutch - fine
- Walbro fuel pump - fine
- Tuned by Dr Drift on a safe tune of 236rwkw at only 15psi, easy to drive (I drive it everyday) and decent fuel economy. Will easily get 450kms to 50 litres with highway driving.
The wheels are 18's, with Kumho ku36's on the rear. - should be ok by the looks.
  • Replies 89
well unless you know how to take the turbo and injectors out, i wouldnt do it yourself. But alot of those mods aren't standout type mods, so you should be fine for an ID inspection.
I'd leave the turbo on if you take it through regency as with the Z32 AFM - Only if you get pulled up on it. I'd leave the nistune ecu, absolutely no way they'll know, even if they pull the ECU apart I put my balls on the line they won't know what they're looking for. Injectors can be a kent to do, turbo timer could take 2 minutes.
The 34 looks stunning mate btw!
Yeah those look pretty bad - though I've seen worse (check out some of the r33s on the road!)
Anyways, you can polish them up with various products - I've tried just about everything from plastx to toothpaste to brasso. I recently used one called 'glassylite': http://www.glassylite.net.au/ which was supposed to have a UV sealant and stop the clouding happening again. Guess we'll see if it works!
Got other pics of the car?
Another prospect car.
car 6 link
My only concerns are:
1. its nearly due to 100k service
2. selling it on behalf of his friend who is over seas
3. not sure exactly what to look for when inspecting it (anyone come along with me help me check it out)
i've seen this car parked on the side of the road in Modbury with the for sale signs up in the window. It looked VERY clean on the outside
The guy i rang "Jeff" was selling it on behalf of his friend who was over seas, i dont know how that would work (signing it over) without him being there :S
But im sick of seeing silver skylines, gotta go black or red :P
Edited by Blazk
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
